Difference in a 420 and a 428 chain??
5 replies to this topic
  • bretskiaz
Posted July 08, 2010 - 03:18 PM
New to riding and just purchased an '03 TTR225.
After a few rides I've decided that I needed more low end power and after reading the threads decided to change my front sprocket to a 14T and my rear sprocket to a 59T ... however I can't find any information on the difference between a Renthal 420 and 428 130 link chain.
Can anyone explain the difference and offer a recommendation on what to use?
Thanks!
  • davidl9999
Posted July 08, 2010 - 03:32 PM
Renthal R1 is a standard (non-o-ring) chain. The primary difference between 420 and 428 is the pitch of the links. A 130 link 428 chain will be longer (and generally speaking, heavier-duty) than a 130 link 420 chain.
Doesn't the TTR225 use a 520 chain? :)
if it were me, I'd just drop the front sprocket 1 tooth and see if that was enough of a change. That way, you don't have to buy a new chain. You can go down to a 12T on that bike (I think).
  • motovita
Posted July 08, 2010 - 07:01 PM
WHOAAA, 420 and 428 chains are the same pitch (the 4 means 4/8" which is of course 1/2"). They will be the same length, the width is greater on the 428.
The TTR 225 uses a 428 chain I believe.
Edited by motovita, July 08, 2010 - 08:24 PM.
  • davidl9999
Posted July 09, 2010 - 08:07 AM
orly. :)
What the hell was I thinking... of course that's right. 428 has longer pins. :banana:
  • Smacaroni
Posted July 09, 2010 - 08:15 AM
Nope, just finished replacing a chain/sprocket on the 225, came with a 428 O-ring stock. Unfortunately I couldn't find a O-ring replacement.
It's probably possible to upgrade it to a 520, but that's bordering on excessive. My street bike uses a 520 or 530 (depending on what you want) and that puts out 68 HP.
IIRC, you can use the rear sprocket from a XT225, you just need to drill out the holes because the XT uses smaller sprocket studs. The front sprockets are the same.
I ended up with the RK 428MXZ if you want a gold RK chain it's GB428MXZ
Do not get a RK 428-M, it's not strong enough.
  • DrThumper
Posted July 09, 2010 - 11:31 AM
420 chain? Is that like smoking the whole bag in one sitting?:)
RegisterSign InClose
