Rear Axle and Front Sprocket Size. Help.
8 replies to this topic
  • JJ1
Posted July 07, 2010 - 09:07 PM
This is a stupid question but o well. I have called 3 yamaha stores and not a single one of them can tell me the size of the socket needed to remove the rear wheel and also to change the front sprocket. It cant be that difficult. I don't have sockets that big and I only want to buy those sizes. The bike is a 2007 YZ450F. Thanks for your help. :):banana:
Posted July 07, 2010 - 09:43 PM
It's a 27mm. (A 1 1/16" works) You'd think they could have asked one of the techs.
  • jbach
Posted July 08, 2010 - 06:01 AM
yeap, 27 mm. a crescent wrench works just fine if you don't want to spend the 15 bucks on a 27mm socket.
Posted July 08, 2010 - 06:43 AM
I want to watch you use a Crescent wrench on a front sprocket. Posted Image
  • Luigic81
Posted July 08, 2010 - 07:39 AM
I would not use a crescent wrench on something that requires 90 ft lbs of torque
Posted July 08, 2010 - 08:25 AM
Yeah, but that's just you. :banana:
More seriously, it depends on the wrench and the fastener. I have a 15" Blue Point CW that will do 90 ft/lb on a good wide nut, no problem. Overall, though, you make a good point. :)
I just want to see how someone gets a Crescent wrench of any real size ON the front sprocket, never mind actually removing it.
  • JJ1
Posted July 08, 2010 - 08:45 PM
Is it a 27mm for both the front sprocket and the rear axle? Both of these are the same size? Thanks for the input.
Posted July 08, 2010 - 09:38 PM
Yes..
  • almostinvincible119
Posted July 09, 2010 - 06:04 AM
What?! This whole time I was using a 28mm? Man, I was lost.
  • 5 replies
  • Hot  113 replies
  • Hot  36 replies
  • Hot  30 replies
  • Hot  38 replies
