yz426 / yz400 clutch hub the same?
1 reply to this topic
  • bink98xcab
Posted July 07, 2010 - 09:24 AM
my bro has a yz426 (01) and the clutch is very grabby as in you cannot adjust it at all. i took it apart and the hub has a lota of play like the nut isnt on tight when in fact it is on very tight w/ an impact. so i was wondering if a yz400 hub was the same, since i can get one of those dirt cheap. any other help on the problem would be greatly appreciated
  • Birdy426
Posted July 07, 2010 - 10:40 AM
Nope, they are not the same. Hub shouldn't be loose, tho, as it's on a splined shaft. Pull it apart and make sure that the thrust washer is there between the basket and hub, and that it's not hung up on a burr on the splines...
  • Hot  79 replies
  • 0 replies
  • Hot  33 replies
  • 9 replies
  • 0 reviews
