yzf450 chain jerking?
13 replies to this topic
  • mxkid23
Posted July 05, 2010 - 12:50 AM
when im in first at low rpms and i gas it i can feel the chain rubbing against something and the whole bike feels like it jerks a bit . could it be because i adjusted the sag? any ideas?
  • The Spanky
Posted July 05, 2010 - 05:41 AM
If the chain is rubbing against something, then you either have a bent rear sprocket, a bent chain guide, or the rear wheel is mis-aligned.
  • ekulb14
Posted July 05, 2010 - 06:30 AM
could also be your chain is to loose and when you get on the gas it snaps forward. ive noticed on some 450's if you cruise in 1st and givre a little bit of gas you do heard a snap when the chain tensions.
  • MELK-MAN
Posted July 05, 2010 - 07:33 AM
yup, 4st hits every 4th revolution so low rpm will get the chain "slapping" as it goes from tight to loose.
  • mxkid23
Posted July 06, 2010 - 11:57 AM
oh okay yeah it snaps a bit so is this normal?
  • WB450
Posted July 06, 2010 - 12:26 PM
If your chain is adjusted properly it is.
Post #6.
http://www.thumperta...098#post9304098
  • theuberacer
Posted July 06, 2010 - 12:29 PM
yeah, especially on the big torquey 450s, at idle a fair amount of "chain slap" is normal.
  • the white stallion
Posted July 06, 2010 - 12:43 PM
And check your chain guides for wear if you hear metal rubbing and the inside of your frame.I'm willing to bet your chain is too lose.
  • shortburb
Posted July 06, 2010 - 12:58 PM
Small throttle openings will give sputtery performance on the 4 strokes and you can get a tugging feeling. The bike isnt pulling smoothly.
  • FIVEWIDE
Posted July 06, 2010 - 07:07 PM
sounds like you have bearing play to me, see if your rear tire moves side to side.
  • mxkid23
Posted July 06, 2010 - 10:25 PM
tire doesnt move at all it tuggs a bit im going to agjust the chain a little and it should be just fine.
  • rdefonce
Posted July 08, 2010 - 09:06 AM
just be careful not to over-tighten your chain. Remember, when on a stand the chain slack should be between 1.9 - 2.3 inches.
My chain is adjusted to about 2", and I often get "chain slap" when opening the throttle at low RPM. That's normal.
  • Luigic81
Posted July 08, 2010 - 05:27 PM
you running o-ring or normal out of curiousity?
  • mxkid23
Posted July 09, 2010 - 12:56 AM
normal
  • Hot  30 replies
  • 10 replies
  • Hot  36 replies
