rev limiter?
2 replies to this topic
  • Linacmechanic
Posted July 04, 2010 - 05:33 PM
Does having the grey wire still in-place on a 03 wr450 act as a rev limiter? have not clipped it yet. playing with jetting, the previous owner put on a GTYR pipe and muffler and did not rejet. develops a sputter at the same spot no matter what gear or engine load.
  • William1
Posted July 05, 2010 - 03:55 AM
No, the grey wire only toggles the CDI between engine maps.
Probably bad jetting. Did the PO do the throttle stop?
  • Col Psoas
Posted July 05, 2010 - 11:11 AM
they gray wire is not a throttle stop... the throttle stop is, the gray wire is a different ingnition map setting
you definately need to rejet
