"Pads" For valve adjustment.
11 replies to this topic
  • jw423
Posted July 02, 2010 - 11:30 PM
I'm new to the new dirt bike thing but how long and do other bikes have this change the pad to adjust the valves thing going on? Doese anyone know why the new system? It sure seemed a lot more easy to just loosen a nut and turn a screw. My 2006 quad has the old way of adjusting. Is this a Yamaha thing? Do you guys like the pads? Seems nuts to me but I guess there must be a reason....:)
  • William1
Posted July 03, 2010 - 01:09 AM
99% of modern engines (IE, those in the last 20~30 years) use pad/shims or some variation. The screw/nut/ball time is more prone to wear and as they wear, adjustment becomes near impossible always loose due to the ball making a 'pocket').
Because the shim method is so wear free, adjustment is infrequent and when it does need adjusting, it is because the valves are beginning to recede and out of adjustment valves are a sign that a overhaul is imminent.
Posted July 03, 2010 - 07:16 AM
When the cam sits directly on top of the valve lifter, which sits directly on top of the valve, how else would you do this?
  • jw423
Posted July 03, 2010 - 09:02 AM
Cool thanks for the input. My old bike is a 1990 XR250R and my 2006 Suzuki Vinson both have the old style of adjusters. I can see how the shim leaves less movable parts. So I guess this is the norm now. Do you know if the shims are make and model specific? Or is there an industry standard.. ya right huh.
Thanks again.
  • jw423
Posted July 03, 2010 - 09:07 AM
Well you make a good point and I see how the pad is the best way to adjust that system. However having the cam sit directly on top of the valve is not the only way to build a head. How about having a hydraulic lifter in there, now even less adjusting eh.
I was just trying to find out what the norm is now and why it is designed that way. maybe I wasn't clear.
Posted July 03, 2010 - 02:02 PM
... having the cam sit directly on top of the valve is not the only way to build a head. How about having a hydraulic lifter in there, now even less adjusting eh.
It's an engine designed to be used in competitive racing, and run at speeds that would have had you declared insane for suggesting them in the same sentence with "reliable" as little as 20 years ago. Hydraulic lifters are not suitable for such applications.
As far as other layouts for the valve train, it's true, there are other ways, but none as simple, effective, and reliable with as few moving parts and as little total valve train weight to be managed at high rpm. Also none which produce so little total wear.
Besides, where the Yamaha engine is concerned, you won't really be doing that much adjustment, anyway.
There was a similar setup used in the original Kawasaki 900cc Z-1 engine wherein the adjustment pad sat in a pocket on top of the lifter. This meant that the cams did not have to be removed to adjust the valves, but it did require a special tool for the job, and raised the possibility of damaging the valve train during an adjustment. I'm not certain why the setup was dropped, but it was.
  • William1
Posted July 03, 2010 - 02:38 PM
Thanks again.
No, other than diameter (of which there are a few) If a bike uses a 9.48 Dia. shim, then any 9.48 dia. shim will work assuming it is the right thickness of course. I think there are like three diameters used in a majority of bikes. So if you serviced bikes for a living, you'd own three kits.
  • Flagstaff
Posted July 03, 2010 - 08:16 PM
Shims over buckets were dropped because they were occasionally spit out at high RPM. Imagine that mess.
Posted July 03, 2010 - 09:46 PM
I had heard tales like that, but I haven't ever seen any hard evidence to support them. Strikes me as credible, though.
  • Flagstaff
Posted July 04, 2010 - 07:32 PM
Was more a problem with street bikes, and rare. I had a coupla bikes in the early to mid eightys with the shim over arrangement and no issues. Special tool was cheap ($10+-) and much easier than pulling cams.
  • Flagstaff
Posted July 04, 2010 - 07:36 PM
Just occured to me, with shim over, possible wear on shims due to direct cam contact? Could add an extra step to adjustment.
  • William1
Posted July 05, 2010 - 03:54 AM
My XT350 Yamaha has shims over buckets. So far, none have jumped out. Nor has any wear been apparent. There is a pretty large contact patch (fat old cam lobe) and at 14,000 miles, not nticable wear. Seems to, the bucket tends to rotate about and the cam does not hit the same point.
