factory fork settings 98 yz400f
2 replies to this topic
  • Guest_Guest_*
Posted January 19, 2001 - 07:06 PM
any of you guys know the stock fork settings
on a 98 yz400f? i just bought one and am
reoiling my fork and shock just wanted
some thing to go by to help tune it in.
  • F-Pilot
Posted January 19, 2001 - 07:59 PM
The stock oil height is 130mm but most run closer to 100mm not sure about the clickers usually about 9 out on compression and 12 out on rebound.
  • MrMXer
Posted January 22, 2001 - 01:39 AM
Not sure how you are measureing the oil heigth, but I run mine at 70mm. I set mine making sure that there is no oil in the outer chamber. (meaning no oil between the lower part of the fork and the top part of the fork) I have set-up other bikes in a range between 80mm-65mm. I believe 70mm is equal to around 100mm if you allow oil in the outer chamber.
  • 0 replies
  • 10 replies
Motocross
  • Hot  491 replies
  • Hot  47 replies
