2007 YZ450F race sag
3 replies to this topic
  • ReedRulz
Posted June 24, 2010 - 05:20 PM
I have a 2007 YZ450F and just had my suspension rebuit. Checked my race sag and it is 96mm. Is this good or should I change it? I ride MX only. Can you change the sag without taking the sub frame off?
Posted June 24, 2010 - 05:59 PM
That's what I would run unless the front end dives like crazy entering a corner. That and run the fork up in the clamp about 5-7mm.
The sag can be set by reaching in from the right side with a piece of aluminum bar stock to break the lock ring loose, then rotating the spring by hand, grabbing it on the bottom end. then you can lock the ring back down again.
Or, there's this nifty gizmo:
http://www.thumperta...ad.php?t=881489
  • ReedRulz
Posted June 24, 2010 - 06:09 PM
Thanks grayracer you're the man.
  • Polar_Bus
Posted June 25, 2010 - 07:44 AM
The shop that rebuilt your suspension should have given you a sag recomendation spec (unless by "rebuilt" you mean a simple fluid and seal change at your local Yammi dealer). FC that did my suspension recommends 104 mm on my peticular setup.
  • On January 15, 2017
  • Hot  38 replies
  • Hot  28 replies
  • Hot  36 replies
