2004 Oil pump Idler gear installation
2 replies to this topic
  • pdunlop
Posted June 24, 2010 - 01:42 PM
Bike is a 2004 WR 450F that I am rebuilding from boxes of parts
Just wondering if the oil pump idler gear is meant to have anything fitted behind it (i.e shims or washer), or does it just run against the crankcase alloy surface? I couldn't see anything in the parts listings to fit there...
See below for what I mean:
Posted June 24, 2010 - 03:02 PM
Runs directly against the case. There's a washer, then a snap ring on the outside.
  • pdunlop
Posted June 24, 2010 - 03:17 PM
Thanks for that!
How odd that it runs directly against the casing - I would have expected it to wear the alloy.
