Oil comes out of case saver hole
8 replies to this topic
  • Parx_400
Posted June 23, 2010 - 06:35 PM
So when I got my bike the top hole for the case saver was stripped. It seemed to have some bite if I put a longer bolt in so I did this. Well I went too long and if there is no screw in the hole oil comes out. It does not seem to leak if I have a screw in there but I wanted to know if i'm messing anything up? Will the screw hit something if its way in there?
  • Parx_400
Posted June 24, 2010 - 05:49 AM
anyone?
  • JDLowrance
Posted June 24, 2010 - 11:38 AM
What case saver hole are you talking about?
  • Parx_400
Posted June 24, 2010 - 12:11 PM
Where the top bolt goes in.
  • Jackazz
Posted June 24, 2010 - 12:25 PM
I'm guessing your best bet is to see if anyone has pics of their 03'-06' cases split, so you can see what's inside. :)
  • William1
Posted June 24, 2010 - 01:46 PM
Your too long screw punch out the inside of the case. You need to Heli-Coil or TimeSert it and use the correct length bolt. You may have to get a sealing washer on it to prevent oil seepage.
There is no way for me to know if you are going to hit a trans gear as I have ni idea how far into the trans casing you are going.
  • Parx_400
Posted June 24, 2010 - 01:51 PM
It’s not too far. Can I just tap the hole to the next size? I have a very good tap and Die kit from Snap on. It would not take much to put the next size bigger threads in there. It’s so stripped that I can push the stock length bolt in without even turning it.
  • William1
Posted June 24, 2010 - 05:03 PM
That is the incorrect method to repair your bike.
Doing what you propose would mean that your would also have to drill out your case saver to suit.
  • truebluedrz
Posted June 26, 2010 - 03:54 PM
i'd be more worried about the piece of case you punched out and is floating around your engine??
