Clark Tank Question
6 replies to this topic
  • yrun
Posted June 22, 2010 - 06:37 PM
I've installed the Clark 3.3 gallon tank and had to add a longer gas line; Didn't have any 90 degree elbows so I basically looped the gas line (180 degree) back toward the carb. The line may be a bit lower than the carb now. The other options are too install a 90 degree fitting and clean it up a bit or run the petcock backwards so barbed fitting is pointing to the carb..
What have you others done that have installed the clark 3.3?
Thanks,
Joe
  • resinlips
Posted June 22, 2010 - 06:53 PM
Get an 06 petcock and problem solved. It faces the rear so it's just a straight line to the carb.
This is something I've needed to do since I went with a Clark tank 8 months ago.
  • comtnrider
Posted June 23, 2010 - 07:15 PM
I just run the stock petcock backward, not a problem and the line goes straight to the carb (with a small in-line filter). :)
  • Baja trail Rider
Posted June 23, 2010 - 08:01 PM
I run it backwards no problems .
  • yrun
Posted June 23, 2010 - 08:35 PM
I like the idea of the 06 petcock the best..
thank you for the replies....
  • resinlips
Posted June 24, 2010 - 05:43 PM
The petcock and fuel line stick out into the shread zone when you run it backwards. Imho
  • JimL
Posted July 04, 2010 - 05:09 PM
i just bought the 06 petcock.
