one more jetting question (should be quick)
7 replies to this topic
  • billy the kidd
Posted June 21, 2010 - 03:48 PM
i have an 07 wr 450 that has all of the uncorked mods,, with a fmf powercore 4 , and had been rejetted, and has always ran great,, today i put a mega bomb header on to replace the stock header, my question is do i need to rejet again for the addition of the header, or should it be ok,,,, thanks again ,,
just a note ,, it seemed to be a little on the rich side of jetting before the new header not bad just safe,,
  • Mutu
Posted June 21, 2010 - 10:22 PM
Ride it and find out!
  • billy the kidd
Posted June 23, 2010 - 06:35 AM
really ,, 60 views and the answer i get is ride it ,,,,wow thanks a lot for all the help,,,, i just figured that some one out there had done about the same thing ,and knew weather or not i would need to rejet,,, whatever
  • tribalbc
Posted June 23, 2010 - 06:57 AM
All bikes can run differently to the same mods. The only way to know how YOUR bike is going to react is to ride it and find out.
That said I doubt a header will make a whole lot of changes, maybe a tweak of the fuel screw.
  • CanadianWR450
Posted June 23, 2010 - 08:07 AM
The megabomb will lean it out a LITTLE, probably not enough to have to touch jetting outside of fuel screw (If you don't have a adjustable one....get one...)
If you were a LITTLE rich to begin with, your probably good to go....but as Tribal said above.....the proof is in when you ride it.......
  • billy the kidd
Posted June 23, 2010 - 09:58 AM
thanks that is just what i was looking for,,,, i know that every bike is different,,, i was just looking for a rough idea,,,, thank you all again ,, i will ride it to double check and i do have an adjustable screw,,,,
  • Mutu
Posted June 23, 2010 - 10:57 PM
So what, would you just change jetting with out riding it first? :)
  • billy the kidd
Posted June 27, 2010 - 07:03 PM
no i was just hoping that someone might be able to tell me what i might be able to expect before i started,,smart ass
