DRZ400 Manual Cam Chain Tensioner
7 replies to this topic
  • MIRAGE
Posted June 19, 2010 - 11:31 PM
Hello guys.... Today i found this link on youtube and i would like the experts to let us know how good is this way to replace the ACCT to the MCCT... it explains in details how to do it. and since iam changing it i would like to know if its a good way to make it the same as the video shows
Thanks
  • suzuki sm nut 123
Posted June 20, 2010 - 04:29 AM
http://www.thumperta...ad.php?t=639008
yes, that will get it done, but read this also
  • GOF1
Posted June 20, 2010 - 05:28 AM
I never understood the need to remove the exhaust. Just seems like extra work.
  • happy seal
Posted June 20, 2010 - 05:59 AM
People overthink this install. remove old, install new, adjust. Like Eddie says = 5 minutes. If youv'e never done one = find proper size tools drop tools three times, kick dog outta the way, help kid get unstuck from the trampoline frame= 20 minutes!
Am I right?
  • MIRAGE
Posted June 20, 2010 - 07:23 AM
hey man i already check that but on the video does not look that complicate as it explains in the threat.... :thumbsup:
if i do it like it shows on video is it ok i guess ?
thanks
  • Erik Marquez
Posted June 20, 2010 - 07:40 AM
thanks
The "How to" thread is a complete guide for someone that needs a step by step walk though.
There are short cuts, and there are short cuts that can cause you to destroy the motor.
It is a simple install, that folks often don't understand.
What I have found is no matter how I do a Tech write up, someone will comment I left out steps, someone will comment i added to much detail and confused people, a few will say "things like this should only be done by professionals" and MOST will understand it's just a guide, a way to do the job. Use the write up as a guide and successfully get the job done.
The quick way.
  • "back off the motor"
  • Use a long extension, and a wobble drive hex end socket.
  • Reach in from back near the exhaust and undo the two ACCT bolts, put the new MCCT in place after having backed off the adjuster and o ring. Tighten the retaining screws back down.
  • Run the MCCT adjuster in finger tight, start the motor, back out the adjuster till you hear it rattle, tighten just till the rattle stops. Lock down the adjuster lock nut
Your Done..GO ride.
  • MIRAGE
Posted June 20, 2010 - 10:27 AM
Thanks a lot and i do appreciated a lot of what you said. i just found it more convince of the easy way that you describe and as the video shows is the same.... Thanks a lot buddy
I will update when i get the MCCT and install it on
Regards
The quick way.
Your Done..GO ride.
  • MIRAGE
Posted June 20, 2010 - 09:58 PM
good morning guys.. i just wanted to let you know that i just pick up the MCCT today from the post and i will be installing it this afternoon due to the fact that iam working...
this is the MCCT that i bought... if anyone interested to get one
Thanks
http://cgi.ebay.com/...=item19bcf01f91
Suzuki DR-Z400S 2017 by Chris.GVS
  • 0 reviews
DRZ to become Adv bike, what bike for DS & singletrack? by BlueHeart
  • Hot  55 replies
My dirtbike accedent that just changed my life by Colorado dirt bike kidz
  • Hot  142 replies
Suzuki DR-Z400E 2016 by DirtShow
  • 0 reviews
Found Dr-Z400 12 years old "Factory PACKED" by ezkhan
  • Hot  28 replies
