carburetor leaking intermittently
2 replies to this topic
  • yz450scott
Posted June 17, 2010 - 05:28 AM
Help! I completely cleaned my carb, removed all the jets, cleaned them with carb cleaner and blew everything out with air. Now that I reinstalled everything, my carb overflow leaking intermittently. Every minute or so, about 10 drips come out the overflow fast. I removed the carb and checked the float height and verified it was at specs. 8mm..It did it again, so I reset the float at 10mm which I think is the right direction to now allow as much gas in the float bowl. It still does it...What am I doing wrong? Is there possible some other cause? I took out the needle valve and assembly that it goes into and it is clean and the tip of the needle looks new...I am stumped...Any help would be appreciated...:thumbsup:
  • Dudemeister
Posted June 17, 2010 - 06:20 AM
How does your float valve look? Is it moving smoothly (remove the float bowl, look from the side and move the float up and down)?
Posted June 17, 2010 - 08:00 AM
It appears the float needle isn't sealing, which is either due to dirt embedded on the tip (may not be visible) or a wear or dry-out condition.
  • Hot  47 replies
  • 10 replies
  • On January 15, 2017
  • Hot  28 replies
