Help! Wiring up wr450 07 Baja Design switch
7 replies to this topic
  • Obijuanx
Posted June 13, 2010 - 06:45 PM
i honestly have no clue on how to wire this thing up, i have looked all over for some sort of faq or picture diagram, any help with this would be great. Hopefully someone has done this before and can post some pics of how they got there setup to work
  • PBDBLUE
Posted June 14, 2010 - 06:36 AM
What are you trying to wire up - lights, ignition, dual sport? Also which switch do you have?
  • Obijuanx
Posted June 14, 2010 - 07:51 AM
its a full switch has everything but the start making the bike street legal. I need to wire up the new headlight along with all the new blinkers. I think i understand that i need to route the power to the new switch rather than the standard on off on the Wr and then go from there but i just dont know how to setup the blinkers or my highs and lows.
I was hopping someone has done this before, making this a lot easier.
  • KennyMc
Posted June 14, 2010 - 10:29 AM
Well, I added the Baja Designs Dual Sport kit to my 07 WR450 but the kit came with all of the instructions and new wiring harnesses.:thumbsup:
  • Obijuanx
Posted June 14, 2010 - 10:46 AM
its just the switch i have my own lights, so basically i am trying to figure out what i need to plug from the standard harness into the new switch.
  • PBDBLUE
Posted June 14, 2010 - 06:12 PM
Out of the 4 pin connector that goes to the existing switch the red wire is 12 volts from the battery and the brown lead is the switch output to the cdi. If you want to add an led like the oem switch you need an led with a diode and a 1k ohm resistor in series between the red\black and black leads.
Edited by PBDBLUE, June 14, 2010 - 07:37 PM.
  • fwdtomco
Posted June 14, 2010 - 06:25 PM
Try this link . I wired my Baja Designs switch into the Yamahas headlight , tail light , horn and kill switch . Works great, after I figured out the switches internal schematic. Which I believe they only send out when you buy the complete dual sport kit.
http://www.bajadesig....ickstarts).pdf
  • fwdtomco
Posted June 14, 2010 - 06:42 PM
sorry that link dosent seem to work
do a search on my posts (there arent very many) and you will find the post about the headlight switch and the link works from that reply to my post
