rotor replacement
2 replies to this topic
  • pbviking
Posted June 13, 2010 - 01:28 PM
Hey Guys,
I had to replace my rear rotor. Fit up a new OEM and scott shark fin. Problem the new rotor/pads has a slight drag. Is this normal? I can spin the tire with one go pull and the tire will rotate freely about 2 turns. You can hear a little rub as the tire spins. I am not sure where to go from here.... I took a 5 min ride and when I got back touched the rotor. It was hot. I would not be able to leave my hand on the rotor for 5-10 seconds.
Any help would be appreciated
Posted June 13, 2010 - 02:04 PM
None of that sounds very unusual, really. Disc pads don't "return" or draw back from the rotor when you release the brake, and they normally run pretty hot.
  • pbviking
Posted June 13, 2010 - 04:06 PM
thank you gray
i will keep an eye on it the next time I go ride
  • 9 replies
Is the 2016 GYTR Yamaha YZ450F too fast? by Fryboy
  • Hot  241 replies
  • 0 replies
  • 5 replies
yz400f throttle bog by yz400fmaniac
  • Hot  28 replies
