wr400 water going to expantion tank?
5 replies to this topic
  • higgy456
Posted June 12, 2010 - 11:36 AM
Can anyone help me please , i have just rebuild my bike after detonation and its running ok except it keeps overheating , when i put water in the radiator the pressure builds and pushes the water to the expantion tank, please note that i have just tried to reseat the valves so i was kind of thinking it was down to the shims being the wrong sizes what do you guys think?:thumbsup:
  • William1
Posted June 12, 2010 - 01:42 PM
If, with a full radiator, radiator cap off, engine running, you dsee bubbles, you have a bad head gasket/waped head/poorly fitted oring. If it looks good, it could well be just a bad radiator cap.
  • higgy456
Posted June 12, 2010 - 02:03 PM
so if i see bubbles coming up then there is a prob with the gasket/o rings or warped head?
  • William1
Posted June 13, 2010 - 03:01 AM
Yes, that is correct
  • tt3506spd
Posted June 13, 2010 - 03:18 AM
And that means a lot of $$$$$ down the drain.....
  • eu001939
Posted June 13, 2010 - 10:04 AM
Is the water pump working and are all the hoses connected correctly ?
