Looking for more "snap"
Posted 12 June 2010 - 04:18 AM
As you all know, these bikes are sluuuuuuugish at the twist of the throttle. I'm looking for advice on how to give him a little throttle "snap". This should help him out on accelerating out a turn, jumps, hill climbs, and so on.
Right now it is a bone stock 09. What to do first?
Thanks
Posted 12 June 2010 - 04:56 AM
Posted 12 June 2010 - 12:17 PM
Posted 12 June 2010 - 06:40 PM
heres some options U can find most of this stuff on ebay cheaper
http://www.twobros.c...mpleKLX110.html
Posted 12 June 2010 - 07:11 PM
Posted 12 June 2010 - 07:14 PM
Posted 13 June 2010 - 06:52 PM
Thanks
I just uncorked my completely stock 2005 KLX110 with fantastic results for very little money. Throttle response is way better, bike has more power, starts easier, doesn't bog out anymore etc. All for very little money.
First I unbolted the airbox and removed the snorkel from the air inlet. It's a small rubber 90 degree piece and it pulls right out. Next I replaced the stock air filter with a Twin Air foam filter ($10). Then I took the carb off for the first time and replaced the stock 38 pilot and 80 main with a 40 pilot and 85 main jets. I then went to Radioshack and bought their "steel flat washers" kit (part # 64-3022A) for $2. You need the second smallest #4 washer in the kit. Take the stock needle out of the slide and place the #4 washer under it. Reinstall the carb and set the air screw to 1.75 turns out. Reset the idle if you have to, I didn't.
You now have uncorked your bike and have a ton more power/snap that you were looking for. All for less than $25!
Posted 13 June 2010 - 07:20 PM
asg5265 said:
Yep, but intentionally. And still had huge gains over stock. My bike doesn't see much top end, mostly low end torque riding. Plus i'm pretty sure drilling the washer hurts you on the low end a bit but helps in the top end. I also like the stock exhaust for the stealth factor. Runs clean.
Posted 14 June 2010 - 06:56 AM
Posted 14 June 2010 - 01:06 PM
Depending on where he is a year from now, we may go 140 or maybe a 65 smoker. In the mean time, I'm trying to ease him into the sport.
I've done the air box mod and have ordered a fist full of jets to play with. Why is 5/8" the magic number for drilling the exaust? I've heard of people drilling the head pipe and others drilling the muffler. Do I need to drill both ends or are they talking about the same thing? Where I come from the head pipe and muffler are on opposite ends. He did say he would like it a little louder.......
Posted 14 June 2010 - 02:23 PM
Posted 14 June 2010 - 03:33 PM
Thanks
Posted 14 June 2010 - 04:21 PM
Posted 17 June 2010 - 10:54 PM
Eric
Posted 18 June 2010 - 05:03 AM
Posted 19 June 2010 - 03:45 AM
Thanks TT for the tips!
Posted 24 June 2010 - 04:40 PM
Posted 24 June 2010 - 04:42 PM
2005_xr250l_thumper said:
Um I'd suggest what I did when my daughters TTR110 was too wimpy....SX65 then YZ85
