Hey guys, I've been chasing down problems with this bike for a while now. Basically, the oil isn't getting to the head. To verify this I took the banjo bolt loose on the oil line and there was no oil. I had the clutch cover off the bike and checked the oil pump. I spun it manually with the gear and could see that it was pumping and that the o-ring and spacer were still in place.
Then I put it back together and checked that I hadn't done something stupid with the oil filter. It was in good and while I had it off I started the bike for a couple of seconds to see if the oil was making it that far. After less than a second I could see that the oil was flowing up into the filter housing. When I installed the filter and took loose the lower banjo bolt on the oil line. After about 10 seconds when I started the bike there was still no oil flow so I shut it off. Now I'm stumped.:banghead:. The banjo bolt definitely had air puffing out of it pretty good, but I have no idea what the problem is now. The filter looked like it was saturated almost completely. Please somebody HELP!
