Anyone running 22mm offset tripple clamps?
3 replies to this topic
  • live_to_ride
Posted June 05, 2003 - 07:54 PM
What did they do? Are they worth the $$$$? :) thanks
  • Chaindrive
Posted June 06, 2003 - 03:31 AM
I am no expert, but awhile back I considered bidding on a set of Scott's upper and lower clamps on ebay. They changed the offset of the '98 and '99 models to be the same as what the slight (shorter/closer steering head) frame change made in '00 does: quicker steering/better cornering. At least that is how it was explained to me. How many millimeters difference I can't recall. Are these what you are asking about?
  • FNG241_WR450F
Posted June 06, 2003 - 08:15 AM
Check out the above link. They just did a review on a new set by BPR.
  • Jonesy920
Posted June 06, 2003 - 11:20 AM
I haven't had any problems with "head Shake" or twitchy front end on mine. I have the front shocks up 5mm and the rear wheel moved forward. Grant it I don't ride 80mph ie; desert racing, but I think the adding of a stabilizer was more than enough to compensate for the geometry change. My bike is alot quicker in the tight stuff w/out giving up high speed stability. :)
