cylinder works big bore
4 replies to this topic
  • j-lanne1
Posted June 08, 2010 - 04:58 PM
alright i just put a cylinder works +3mm big bore kit in my 06 yz450, got it all together bike starts and idles, but is really boggy when riding it and doesnt have hardly any power, i tried going up to a 168 main but that did help at all, any ideas would be helpful..
Posted June 08, 2010 - 07:02 PM
Start by verifying that you have the flywheel key in place correctly. Use a probe down the plug hole to see if real TDC lines up with the mark. Then double check your cam timing.
  • mkporn
Posted June 09, 2010 - 02:16 PM
take the rag out of the air box... :thumbsup:
Seriously, do as gray suggests. This is not going to be a huge jetting issue, if the bike ran well with the jetting in it and you did a big bore, it is going to be very close to start with on the big bore and will almost never make as much difference as you noted. You will have to fine tune, but you are not going to need to make drastic changes to bring it back in line....
Posted June 09, 2010 - 03:21 PM
That isn't as far out of the question as you might like to think.
  • mkporn
Posted June 10, 2010 - 08:35 AM
I like to think of sarcasm being a funny way of being serious. I have seen it before and that is the reason I said it comically. :thumbsup:
  • Hot  47 replies
  • Hot  50 replies
  • Hot  113 replies
