426 won't start
6 replies to this topic
  • Guest_Guest_*
Posted January 13, 2001 - 06:29 AM
my 426 will not start , i've cleaned the plug and the carb but no joy?????????????
  • dirtdad
Posted January 13, 2001 - 07:12 AM
Steff, You really need to give more info (ie: starting procedures, settings, location, etc...) to get any suggestions.
  • oweel
Posted January 13, 2001 - 11:22 AM
I had the same problem today (kick it for half hour).
But instead of cleaning I replaced the plug and it started first kick.
I would try a new plug.
  • Boit
Posted January 13, 2001 - 12:40 PM
Yeah, if a fresh plug doesn't get it to start, you'll have to really do some digging. I hope you have gas in the tank and your petcock is open. Sometimes, it's the most basic of problems. Make sure your hot start button is pushed in(closed). if you still can't get it to start, I'd start looking to make sure there is ignition spark. One 426 owner stated that his kill switch was bad.
  • Taffy
Posted January 14, 2001 - 02:39 PM
i had no spark with the plug inn the cap. i then gave it a proper wire brush-with a plug brush-& now it starts every time.
Taffy
  • Guest_Guest_*
Posted January 15, 2001 - 03:55 AM
mate, is your idle too low? When I went a bit richer on the pilot jet I had to adjust more air ( clockwise 1 turn ) goodluck
YZ426F 2001 pilot
  • Numpsy
Posted January 15, 2001 - 05:43 AM
Here´s the most common solution over here.
What brand of plug are You using?
Once a Nippon Denso is flooded, it´s over...
If not already done, replace the plug with a NGK.
Numpsy
  • 0 replies
  • Hot  113 replies
