throttle bog
17 replies to this topic
  • moto-x-411
Posted January 12, 2001 - 08:46 AM
i just left the 2-stroke ranks & bought a 2000/yz426....i read where the 2001 model has eliminated the bog you get when you blip the throttle from idle.....are there any fixes or bandaids for the 2000,or does this not cause as much of a problem as i think it might during a moto?
  • dirtdad
Posted January 12, 2001 - 09:36 AM
read the post "weighting the flywheel"
  • Boit
Posted January 12, 2001 - 09:59 AM
I had a slight hesitation with my 2000 426. I cured it by going from the stock #162 main jet to a #160 and installed the accelerator pump bottom plate from Factory R&D. It's called the P38. I live and ride in metro New Orleans which is at sea level and quite humid most of the time. My jetting might not work for you.
  • moto-x-411
Posted January 15, 2001 - 06:17 AM
thanks for the replies.....boit, i will take into consideration your elevation
  • smitty33
Posted January 15, 2001 - 06:51 AM
anyone got a website or email for "Factory R&D"
Nothing in my local dealers catalogues for the p-38
Thx
Smitty http://www.fastbydesign.com
  • Boit
Posted January 15, 2001 - 12:50 PM
Smitty: When I had ordered the P-38 a few months ago via phone, I asked about a web site and was told that they are working on it. A small ad in Cycle News has only a phone number. 949-206-0894
  • Guest_Guest_*
Posted January 15, 2001 - 06:33 PM
I fixed my "boggin" by learning to roll the throttle insted of poping. Good luck on fixing it.
THUMPER POWER....
  • DPW
Posted January 16, 2001 - 02:44 AM
MX South also has it http://www.mxsouth.com/perp38lit.htm
Dennis '99 YZ400F
  • shredder
Posted January 16, 2001 - 05:07 PM
I have a 98 YZ400 and it also bogs if you quickly "twist the grip", I was used to this with my TT600, I have been reading the service manual and it states this is NORMAL behavior due to the accelerator pump. I noticed other posts about thumpers trying to remedy this, with nobody really getting rid of it completely.
[This message has been edited by shredder (edited 01-16-2001).]
  • Guest_Guest_*
Posted January 17, 2001 - 04:43 PM
Really, try rolling instead poping the griper. Its not a 2stroker. If your a poor boy like me you will learn insted of buying a "acc pump". I think thats what boit said.
  • Boit
Posted January 17, 2001 - 05:50 PM
I don't know why you guys have to roll your throttle on. I can whack mine full open right off idle coming out of a slow tight corner and the response is instantaneous.
  • Guest_Guest_*
Posted January 18, 2001 - 03:56 PM
Boit, how much did you spend on the acc. pump
bottom plate from r&d?
  • Boit
Posted January 18, 2001 - 10:08 PM
Thumper426: If I recall correctly, it was $78 U.S., plus about $7 to have it UPS'd to my door. That might sound exorbitant for such a small aluminum plate, but take into consideration a few factors. The company's R&D expense, CNC machining, and whether it works or not. From my perspective, it has been one of the best investments I've made to get my engine to perform as I demand. I can't tolerate an engine that doesn't respond briskly. If I could not have correct this hesitation, I would have sold it to some poor unsuspecting soul and moved on to a different bike model.
  • smitty33
Posted January 19, 2001 - 04:28 AM
Thx for the great info Boit,
I got one on order now.(p-38)
Do you still have the 00 426, what are you running for a clutch assembly?
Thx
Smitty www.fastbydesign.com
  • DPW
Posted January 19, 2001 - 09:53 AM
Boit,
Did you have to make any changes to the jetting when you installed the P-38 ?
Dennis '99 YZ400F
  • yzman
Posted January 20, 2001 - 09:16 PM
mine had this same hesitation when I would snap the throttle. I took it down to my dealer here in salt lake and talked to a guy who races for the dealer, he did a couple of adjustments to my vavles and my carb and the blip was gone I have had no trouble with it again. He only charged me $45.00.
  • Boit
Posted January 20, 2001 - 10:11 PM
Smitty: I installed the Hinson basket, and yes, I still race this bike. I think I might have lucked out and got a "good" one.
DPW: The only other jetting change I made was to go from the stock #162 main jet to a #160. A little fine adjustment on the fuel screw and my carburetion is spot on.
  • Sandracer_uk
Posted January 21, 2001 - 09:39 AM
i noticed my 400 bogs right ot the bottom of the rev range.
ive just fitted a white bros exhaust and oddly enough the bogging has all but gone and it seems now not to be stalling when braking or on tight turn.
infact i may now rethink buying a flywheel wieght
  • 9 replies
  • On January 15, 2017
  • Hot  28 replies
  • Hot  36 replies
