2010
5 replies to this topic
  • delmas
Posted April 13, 2010 - 04:31 PM
Does the gas tank need to be removed to take off the shock
  • 2milehigh
Posted April 13, 2010 - 05:19 PM
No it doesn't. You don't even need to pull the subframe if you remove the rear fender and the exhaust as they create a lot of working room. Hope this helps.
  • CaptainKnobby
Posted April 13, 2010 - 06:46 PM
I removed mine by just takeing the pivot shaft out at the top and the linkage arm off. came right out!
  • aedwards07
Posted April 13, 2010 - 08:40 PM
CaptainKnobby,
So you just unbolted the shock and where did you pull it out from?And this was with the subframe still on?
  • CaptainKnobby
Posted June 06, 2010 - 04:22 AM
Yes and pulled it out from the righthand side (if you were sitting on it) but take the exhaust section out.
  • aedwards07
Posted June 07, 2010 - 07:03 AM
You can pull the shock out the left side right infront of the numberplate by removing just the 2 shock bolts and nothing else.
  • 10 replies
  • Hot  113 replies
  • 5 replies
  • Hot  36 replies
  • Hot  38 replies
