99 yz 400
2 replies to this topic
  • del III
Posted April 12, 2010 - 06:29 PM
i just got a 99 yz 400 it was leakin oil so bad i couldant ride it more than 5 miles. I fixed that problem now its blowin oil out the breather tube is there a way i can fix that
  • DeeCee
Posted April 12, 2010 - 06:48 PM
How much oil is in the bike ?
YZ400's always blow a little oil out the breather (usually a small patch on the ground after a ride).
If it is blowing a lot out of the breather it is either overfull with oil or you are pressurising the crankcase which is probably due to leakage past the piston rings.
  • del III
Posted April 13, 2010 - 07:27 AM
i put 1.6 courts into it i got that out of the book. i rode the desert 100. when i was done there was some blow back on my frame & swing arm. & i had to put in about a 3rd of a court to top it off after my first 50 mile lap there is no motor noise or piston slap to indicate bad rings
  • 0 replies
  • Hot  47 replies
  • Hot  50 replies
