Water Pump Shaft Bearing Removal?
6 replies to this topic
  • clutchless
Posted April 12, 2010 - 05:29 PM
What's the proper method of removing the bearing that is pressed into the case for the water pump shaft? I assume you need to remove it to replace the inner seal?
Thanks.
  • cbrewer450
Posted April 12, 2010 - 05:46 PM
I took the entire cover to the shop. They popped the old stuff out and pressed the new ones in for me. $25 or so for the work. Worth it to me.
  • clutchless
Posted April 12, 2010 - 05:54 PM
i am thinking of making a press out of a very large old socket, the end is wider then the diameter of the bearing. some threaded rod couple of nuts and some washers. then i can use the old bearing to press the new one back in...
edit...
Home made press for Water Pump Shaft Bearing.
1 6" 3/8" Standard bolt
4 3/8" hex nuts
4 3/8" x 1=1/2" fender washers
1 32 mm Socket
Popped the bearing out in 30 seconds.
Total cost at Home Depot $1.52 (already had the 32 mm socket)
Edited by CLUTCHLESS, April 12, 2010 - 06:41 PM.
Posted April 12, 2010 - 07:08 PM
You're seriously over thinking the matter. Just drive the bearing out with a pin punch by working through the seal. No big deal.
  • clutchless
Posted April 12, 2010 - 07:10 PM
that was my first thought, but i was afraid i would crack the case.
  • coreyl
Posted April 12, 2010 - 07:16 PM
just did it on saturday and it worked fine just be careful not to hit the case and you should be fine
  • Family Man
Posted April 12, 2010 - 11:40 PM
Like GreyRacer513 said, Just drive it out pretty even and you shouldn't have a problem. In general If a bearing has to come out its a good Idea to put a new one back in.
  • Hot  47 replies
  • Hot  50 replies
  • Hot  38 replies
  • 5 replies
