Lowering '04 KDX 220
5 replies to this topic
  • makKX250
Posted April 12, 2010 - 12:26 PM
A friend who is a little bit vertically challenged needs to lower his '04 KDX a 1-2 inches. He has already shaved the seat down to almost FMX level. He is going to try a lowering link for the rear but we have no clue how to do the forks. Does anyone have any information or a "how to" document on the correct way to lower the forks? I don't want "just remove the spacer" or "just cut the springs" as I don't see that as the correct way to do it. But maybe I'm wrong...
  • Ski Pro 3
Posted April 12, 2010 - 12:40 PM
Just slide the forks up into the triple clamps higher. If they hit the bars, get offset bar mounts.
  • Slick_Nick
Posted April 12, 2010 - 02:57 PM
Yup. Only way to lower forks is slide them up into the clamps.
  • makKX250
Posted April 13, 2010 - 07:18 AM
There is a way to lower forks by modifying the internals. I'm asking if anyone has done that with a KDX and would want to share the information.
I guess I should have posted this in the suspension forum. My bad. :thumbsup:
  • Slick_Nick
Posted April 13, 2010 - 07:59 AM
You can remove your preload spacers. I just cut mine down to get less preload, but removing them altogether would work too I suppose.
  • SteveWR450F
Posted April 13, 2010 - 01:59 PM
You could send to suspension shop and they you use a stronger spring but then cut it down to lower forks. I did this once on my first bike. Suspension can become harsh if your not careful.
I would really recommend - lowering link in rear plus move up forks in the front. That should be good. Then just a lot of seat time. If he is anything like most of us, once you get more seat time the bike does not seem so big.
Help ! It refuses to idle...no matter what.. by UglyCasanova
Dirt Bike   Make / Model Specific   Kawasaki   Kawasaki 2-Stroke
  • Hot  36 replies
Phathead racing head? by 1999 Kx 250
  • 16 replies
2008 Rm 250 rear hub/ kx 250 rear hub by WakaMX
Dirt Bike   Make / Model Specific   Suzuki   Suzuki 2-Stroke
  • 6 replies
I drove 1100 miles today for this 05 250 by turbo dan
  • Hot  42 replies
Fouling plugs! NEED HELP! by Enduro488
  • Hot  29 replies
