04 wr starting problem
No replies to this topic
  • Doug Powell
Posted April 12, 2010 - 12:09 PM
my 04 wr450f seems like its not getting voltage to the starter ,cut off relay chatters like a indication of a bad battery but battery is new . fuses ok, tryed to jump start and cut off realy nolonger chatters but engine will just slightly turn over one time / do fuse blocks go bad ?? is it the diode ? bike will kick start but starter seems not to be getting proper voltage even when jump starting with my truck. this problem did not start untill i crashed and bumped the ignition switch hard . took the ignition switch apart and noticed it has a chip in it . another thing i noticed is when pressing starting button when ignition on, the led light goes out anybody know anything about this bizzare problem ???
