***??? new 2010 450 wont start?
8 replies to this topic
  • 2010yami
Posted April 09, 2010 - 08:57 PM
alrighty, i know this has been gone thru already... however... just brought my brand new white 2010 450F home, and the bitch wont start after an hour of kicking in about 6 DEG. celcius. with the cold start knob pulled out. anybody have any ideas? thats all i did to start it, pull the knob and kicked er. is there any on/off switch? anything that might get it to fire up, cause man am i frustrated!:thumbsup:
  • bigredd
Posted April 09, 2010 - 09:28 PM
got gas turned on? it takes a while to get used to them 450s just turn choke on kick it over easy once or twice then kick hard dont give it gas it will crank itself up.... good luck
  • motojase316
Posted April 09, 2010 - 09:30 PM
Must have been a great PD done at the dealer before it went out the door....You need to confirm it is getting spark, there is no on/ off switch but your kill button could be faulty, disconnect it at the connectors in the harness and try starting.
Check the fuel supply for kinks or anything stopping fuel supply.
Remove the air filter and make sure nothing is blocking the intake.
If you have the GYTR controller check for any Diag codes. A foulty sensor could give you trouble too.
  • 2010yami
Posted April 09, 2010 - 09:37 PM
i have tried pulling the "choke" or circut thing open when starting with no throttle... no dice. thing is, buddy had it started in the store a couple hours before i got it home, i just dont get it!
  • bigredd
Posted April 09, 2010 - 09:49 PM
well if your mechanically inclined i guess follow jase316's advice... make sure your getting spark and that the kill button isnt messed up if the guy had it running thats about all it could be... and that you got gas in it and its getting to the fuel injsection?
  • Shogren65
Posted April 10, 2010 - 04:52 AM
My 10' did the same thing. Let it sit over night, it's proby flooded to hell. Pull the cold start knob out find the compresion stroke give it one good kick to energize the system. Then find the compresion stroke again and kick. Mine's been fine ever since.
  • ZMoney520
Posted April 10, 2010 - 08:46 AM
Mine was very hard to start when I got it home as well. I kicked and kicked and it didn't even try. Looked in the manual for some answers. If it is flooded, you do not have to sit on it over night. You hold the throttle wide open and slowly kick it 10 - 20 times. This is how you clean out the FI bike. Then try to start it with a slow kick and then a normal kick. This did the trick.
  • Mike546
Posted April 11, 2010 - 03:45 AM
ZMoney has the correct procedure for a flooded bike. Mine was the same way when it was new and the 10 kicks wide open worked every time.
  • 2010yami
Posted April 12, 2010 - 05:33 AM
thx a lot for the help guys... funny thing is, i tried to start er the next morning, she went second kick. no idea what the issue was the nite before, but shes been running good ever since :lol: loving the feeling of the nibleness tho, good times!:thumbsup:
  • Hot  50 replies
  • On January 15, 2017
  • 10 replies
  • Hot  47 replies
