Airbox onto Carb help
13 replies to this topic
  • moabjeeper
Posted April 09, 2010 - 06:01 PM
Hi Guys, As you can tell I don't post very often as I can usually get my questions answered be searching posts. But I've got a problem I hope someone can steer my right on. I took my Carb off to clean and re-jet with JD's kit. I am in the process of getting everything back together and for the life of me I cannot get the airbox boot to fit back onto the carb. The shock is in the way on the Right side and I can't reach it to help it slip back on. That's it. I was hoping to ride this weekend, but after spending a lot of time I'm about licked. Any help would be very much appreciated.:thumbsup:
It's a 09 WR 450f.
  • JDLowrance
Posted April 09, 2010 - 06:08 PM
Where are you located?
  • moabjeeper
Posted April 09, 2010 - 06:24 PM
Walla Walla, WA area.
  • modroo
Posted April 09, 2010 - 06:44 PM
pull off the back shock, i did it to my 09 450 to get the carb off 2 bolts no big deal
  • moabjeeper
Posted April 09, 2010 - 07:19 PM
I had the shock off to get the carb off initially, but I put it back on after putting the carb back on, then brought the subframe back down to re-attach everything, thats when I started having problems. I will look at it again Sunday. So much for riding it this weekend. I'm glad I kept the KLX300R as a back-up instead of selling it right away.
  • racinteach
Posted April 09, 2010 - 07:24 PM
Just did mine this week and all I did was just squeeze the boot downward and back towards the airbox. slipped right in...
  • moabjeeper
Posted April 09, 2010 - 07:32 PM
I'm not sure if the clearance is a lot tighter on the Aluminum frame or not. That may be part of my problem.
  • MaxPower
Posted April 09, 2010 - 08:04 PM
[COLOR="Green"]sounds silly but make sure the screw on the clamp is backed out far enough
Couldnt hurt to give the boot a shot of WD to help it slip over the throat of the carb
[/COLOR]
  • ohioryder
Posted April 09, 2010 - 08:12 PM
What may have happened is when you slip the airbox between the shock and frame the airbox gets squeezed a little and the clamp around the airbox wants to hold it squeezed in. Once you get it past the shock try and reshape the airbox and that should help it slip on. When slipping the airbox back on try and start with the top and work it down instead of side to side. It will go. You just need to play with it to figure out a method that works for you.
  • moabjeeper
Posted April 09, 2010 - 08:14 PM
WD40 is a great idea. I was beginning to think that I should soap it or something but wan't sure if I wanted dried soap anywhere near the carb. WD 40 should work. Thanks, I will give it a try.
  • tribalbc
Posted April 09, 2010 - 08:56 PM
I always put a dab of oil on my finger, run it around the boot of the airbox, and she slips right on :thumbsup:
  • moabjeeper
Posted April 11, 2010 - 11:26 AM
I just wanted to let the guys who responded that a little shot of wd40 on the airbox and 5 min later its on. Thanks for the replies.:thumbsup:
  • Mtn-Track
Posted April 12, 2010 - 06:59 AM
I just wanted to let the guys who responded that a little shot of wd40 on the airbox and 5 min later its on. Thanks for the replies.:lol:
Not only do I NOT use WD40 (or any type of oil) on a carb boot, but I use carb cleaner to make sure there is NO lubricant on the boot or carb at all. The lube makes it easy to slip it all together but it also makes it slip off real easy, especially on a real long and dusty ride! Bad idea in my book! Lesson learned the hard way....:thumbsup:
Install the airbox first, then install the sub-frame.
  • 123BigcoopDawg576
Posted April 12, 2010 - 07:17 AM
A lil lube never hurt anything :):applause:
BTW on my 08 I use WD40 and the book slips right on :lol:
