Power switch relocation - 09 WR450F
6 replies to this topic
  • JDLowrance
Posted April 09, 2010 - 12:49 PM
For those that have pulled their headlights off and are running number plates, what have you done sith the power switch?
For the life of me I cannot fine a suitable location to mount it.
Any help would be appreciated.
John
  • 123BigcoopDawg576
Posted April 09, 2010 - 12:56 PM
For those that have pulled their headlights off and are running number plates, what have you done with the power switch
I often times switch from a number plate to a headlight and I left the main power switch in the stock location...but then again, I don't have the stock computer.
Hope this helps... :thumbsup:
  • Deserthound
Posted April 10, 2010 - 08:04 PM
This is what I did.
http://s369.photobuc...78.jpg&newest=1
http://s369.photobuc...79.jpg&newest=1
  • slowrider998
Posted April 10, 2010 - 10:01 PM
I want to hide mine for security purpose.Dont know where?I just bought a baja kit and should buy a key switch..
  • snaggletooth
Posted April 10, 2010 - 10:17 PM
Deserthound did a good job relocating the switch for the numberplate. This is how I mounted the BD style key switch. I just ran the kill switch wires to it.
  • JDLowrance
Posted April 11, 2010 - 05:54 AM
Thanks for all of the replies.
I ended up mounting it at the base of the backside of the number plate. There is some flashing that runs between the two mount hole that is just wide enough. I fabbed up a plate to replace the mounting bracket so the unit would be sealed and then popped a few holes in the plastic to facilitate the wiring and longer screws. It's outta harms way and wouldn't know it's there unless you were told.
Would post pics if I could.
Thanks again, John
  • dirtfanatic50
Posted June 09, 2010 - 08:06 AM
On my 05,I just made an aluminum bracket That I attached to the back of the bar clamps ,& changed to a keyed powers switch & added a small led light to show power on.
http://img191.images...5/p10003672.jpg
