Hour Meter Mounting
18 replies to this topic
  • husky390or
Posted April 08, 2010 - 06:45 PM
I was at Cycle Gear today and saw an hour meter mounting bracket that is bolted on under the steering stem nut. Anyone use these? Where are you mounting your hour meters?
  • SparksXR426
Posted April 08, 2010 - 07:04 PM
Just mounted a bracket on the front tank mount and bent in down one side of the frame, this way too its very close to the positive to coil(orange) wire behind the front numberplate. Very clean.
  • 642MX
Posted April 08, 2010 - 07:05 PM
Mines mounted under the seat and on the top of the fender. Its out of the way and I can check the hours when I swap the air filter. :thumbsup:
  • geshields
Posted April 08, 2010 - 07:23 PM
Mine is mounted right above the fuel tank...
http://www.napalmrac...hp?cPath=90_122
  • baja931
Posted April 08, 2010 - 07:30 PM
i have a 250F but that doesnt really matter for this. I have mine siliconed to the head of the frame like on the steering colum i guess. Not sure what to call that part of the frame. But that way i can always see how many hours are on it.
Posted April 08, 2010 - 07:50 PM
This would be my favorite spot. It is totally out of the way, and if it falls off its mount, where can it go? Right in the air box. Since I swap the filter out after every ride day, I'd be able to see it plenty often enough.
  • husky390or
Posted April 08, 2010 - 09:35 PM
Mind sharing some pics?
  • dvn
Posted April 09, 2010 - 02:52 AM
+1 but with a DrD mount.:thumbsup:
Edited by dvn, April 09, 2010 - 07:50 AM.
  • 642MX
Posted April 09, 2010 - 04:28 AM
I can take some this weekend.
  • DPW
Posted April 09, 2010 - 04:48 AM
I have mine mounted on the frame above the throttle cables and in front of the gas tank. I used two-sided 3m tape from Target.
  • CaptainKnobby
Posted April 09, 2010 - 07:43 AM
I have mine zip tied to the throttle cable that runs down the lefthand side of the frame in front of the top side of the radiator
  • 642MX
Posted April 09, 2010 - 07:50 AM
Thats what I was thinking... Its out of the way, I can read it when I swap filters, and its clear of the power washer.
  • WB450
Posted April 09, 2010 - 08:00 AM
I have mine in the same place, but I used the double sided tape that came with the DR.D and I caulked some clear silicone around the base. If it falls off (which I don't think it will) I will go under the seat.
  • CaptainKnobby
Posted April 09, 2010 - 08:05 AM
Velcro also works really well. I have it velcrowed on my 06 at the bar pad and never had it to come off once.
Posted April 09, 2010 - 08:19 AM
... its clear of the power washer.
Another good point.
  • crf450319
Posted April 09, 2010 - 10:04 AM
I've got mine mounted in the same spot as I'd had it on my CRF, on the steering stem with 3M double sided tape. After 170 hours of ride time I'd never had it fall off or had any issues with a pressure washer.
I like to use it to keep track of how much time I've put on the bike during any given ride/race day (a good day at the track for me is 2 hours), I personally wouldn't want to have to remove the seat every time I wanted to look at it. But, that's what so great about not living in a communist society - you can do what ever the hell you feel like doing... within reason of course.
  • humpness
Posted April 09, 2010 - 10:09 AM
i did the taboo and used screws!
  • BlackT5
Posted April 09, 2010 - 10:17 AM
I use that same spot. Out sight so I don't keep looking at it while riding but easy enough to see when you need it.
  • Jim813
Posted April 09, 2010 - 12:18 PM
I have mine mounted in the same spot as well with the same tape. I like to get a general idea of how long I've been riding with a quick glance. I don't pressure wash my bikes, so I don't have to worry about water pressure taking it off. I also took up all the slack in the wire so that if it does ever fall off it will only fall about an inch, and out of the way of anything that could harm it.
  • Hot  113 replies
  • Hot  36 replies
