2000 yz426f please help...
19 replies to this topic
  • climax81
Posted April 06, 2010 - 09:01 AM
Hey all I have a 2000 yamaha 426f and I just had the cases replaced because of a broken bearing hold. Got it all back together and I have a couple of questions?
1. I know these things run hot but after a couple minutes of warming up the radiators are so hot they cannot be touched. Is it possible that the water pump is not working?
2. Cylinder head breather hose has a faint trace of coolant sometimes. I know that the radiator breather hose is down there as well but I swabbed the inside of the cylinder breather hose and there is a trace amount of coolant.
I have had two strokes for a long time and just got into four strokes.
If I could get any info at all it would be awesome.
thanks
Posted April 06, 2010 - 11:17 AM
One is normal. They heat up fast at a standstill.
Two could be normal. It depends on whether the stuff you're finding is coolant or atmospheric condensation. If it's coolant, that means it's in your oil, which is a) bad, and needs immediate correction, and :thumbsup: pretty easy to detect from examining the oil itself.
The oil, if contaminated, should have a milky, foamy appearance, and it the sump drain plug on the bottom of the trans is removed slowly, coolant shouls appear just before the oil.
  • climax81
Posted April 06, 2010 - 01:20 PM
Grey thanks for the advice I drained the oil and and it was a little milky I took a pic of it when I replaced the gaskets I did not replace the water pump seal at least that is what the dealer said. All the gaskets were brand new. What is your opionion and it looks easy to do the impeller seal.
Posted April 06, 2010 - 02:31 PM
That oil looks as if it has a fair amount of fine metal in it, but it doesn't look coolant contaminated. Is there any water at the bottom?
  • climax81
Posted April 06, 2010 - 02:49 PM
no water anywhere in it there was fine metal in the oil filter also it has new cases and clutch so are the small shavings normal?
Posted April 06, 2010 - 02:54 PM
Probably see a drop off in the metal content over the next two oil changes. How much time on that stuff?
  • climax81
Posted April 06, 2010 - 02:58 PM
5-10 mins just put it back together and noticed the residue, I took the rh case off and I am going to have the water pump seal replaced to be safe.
Posted April 06, 2010 - 04:32 PM
Unless you have blocked off the drain port under the pump, the water pump seal cannot leak into the oil.
  • climax81
Posted April 06, 2010 - 05:39 PM
I am just so scared about the breather tube leaking antifreeze, is there anyway to flush the motor oil out? should you be able to spin the water pump impeller and it keep spinning or should it have some resistance?
Posted April 06, 2010 - 06:17 PM
Run that past again?
  • JandJ07
Posted April 06, 2010 - 06:26 PM
I think he is asking how much rotating resistance the water pump impeller should have.
Posted April 06, 2010 - 06:27 PM
Oh, I think so, too, but I didn't think the case cover was off the engine....
  • JandJ07
Posted April 06, 2010 - 06:28 PM
point taken :thumbsup:
  • climax81
Posted April 06, 2010 - 06:29 PM
the water pump is not free if you try to spin it, it will not keep spinning, is it supposed to keep spinning if you flick it or spin it. it will only spin if you keep spinning it. no bad sound coming from the bearing though.
  • climax81
Posted April 06, 2010 - 06:30 PM
fyi I have the case off the engine.
Posted April 06, 2010 - 06:35 PM
It has two seals on the shaft, so no, it won't spin freely on its own. It should feel smooth, but there should be seal friction.
  • climax81
Posted April 06, 2010 - 06:47 PM
thanks anymore ideals on the coolant in the breather hose
Posted April 06, 2010 - 07:41 PM
You're sure it's coolant?
  • climax81
Posted April 07, 2010 - 02:24 AM
yah for sure its green. were not talking a lot but its there
Posted April 07, 2010 - 07:32 AM
Run it for another hour, then recheck the oil condition and coolant level, etc. You can also have the cooling system pressure tested.
