2010 alxe blocks
27 replies to this topic
  • delmas
Posted April 05, 2010 - 12:59 PM
Why are there more markings on the brake side than the sprocket side?
  • husqy360
Posted April 05, 2010 - 01:35 PM
same as my 06 :thumbsup:. no idea.
got some after market blocks and both sides match.
  • delmas
Posted April 05, 2010 - 03:24 PM
thanks for the reply
Posted April 05, 2010 - 03:33 PM
If you look, you'll figure it out. There's a raised lip on the front edge of the left side block to keep the axle from turning. When counting marks for wheel alignment, count from the back.
  • delmas
Posted April 05, 2010 - 03:45 PM
I did order some parts from Ride Enginering and I had no idea how good there customer service is.In this marketplace today it is a nice to know that there are companies out there like ride Enginering.i highly recomend them !!!!!!
  • delmas
Posted April 05, 2010 - 04:13 PM
counting from the back is correct Yamaha puts the lip oposite from Honda or Suzuki.
  • delmas
Posted April 05, 2010 - 04:34 PM
http://www.ride-engi...&pn=YZ-BAB10-MB
I think I like these
  • CaptainKnobby
Posted April 05, 2010 - 04:43 PM
those are the same ones I got for mine from surdyke yamaha for $35.00
  • delmas
Posted April 05, 2010 - 04:52 PM
surdyke yamaha IS A GOOD PLACE
  • CaptainKnobby
Posted April 05, 2010 - 05:29 PM
Yeah! I picked up those axel blocks there and a couple of GYTR air filters for like fifty two bucks.
I'm still looking for a couple of magnetic drain plugs for it.
  • mediumfast
Posted April 05, 2010 - 06:27 PM
You are going to be disappointed with your Ride Engineering axle blocks. I bought a set a few weeks ago. You will find that the axle nut side will have to be milled. Any decent machine shop can do the work. I had them make it .039 thicker than the stock one. I will attach a picture of the final product. When you get them compare the RE blocks (the axle nut side) to the stock ones. The need for milling will become apparent. Make sure you have them champher (sp) the inside horizontal edges. If you look closely at the picture you can see what I'm talking about.
http://i1020.photobu...0F/DSC02513.jpg
Sorry for the complicated post. RE would make it a lot simpler if they would actually make a new part number for the 2010 bike....
  • rickallen124
Posted April 05, 2010 - 06:35 PM
GYTR and Zip-Ty both have magnetic drain plugs for the crankcase. The Zip-Ty one is just a hair shorter than the stock drain plug. The Works Connection axle blocks fit perfectly on the '10.
  • delmas
Posted April 05, 2010 - 06:51 PM
they do list the 2010 as a different part than the 09
  • CaptainKnobby
I looked at the zip ty website and couldnt find the drain plug for the 2010 and I think the GYTR plug is for the earlier model yz's.
  • CaptainKnobby
Posted April 05, 2010 - 06:53 PM
If you hadnt all ready ordered yours from that place I would just get the blocks from surdyke yamaha cause I know those will work.
  • mediumfast
Posted April 05, 2010 - 07:27 PM
Hopefully it will work out for you. I ordered the 2010 part number and what I got didn't fit right.
  • CaptainKnobby
Posted April 05, 2010 - 07:36 PM
Most places may not know that the axel on the 2010 is quiet bigger in circumfrence than the earlier models. I fount this out hopeing to use my rear wheel off my 06 as a stand by with a mud tire on if it was a muddy race.
  • rickallen124
Posted April 05, 2010 - 08:06 PM
Just give Zip-Ty a call, they have one that works. I'm pretty sure that there is a GYTR one for the ten, I just always use Zip-Ty, I even got a magnetic drain plug for my truck from them.
  • motojase316
Posted April 06, 2010 - 12:26 AM
Here are Pro Circuit Blocks on my 2010.Posted Image
  • Mike546
Posted April 06, 2010 - 02:11 AM
Is that nut on far enough? It looks like it's hanging on the last thread. I had my Hammerhead block milled on the right side like he guy above. Compare the thickness to the stock block.
Check this thread from a while back. http://www.thumperta...ght=axle blocks
  • Hot  38 replies
  • 0 replies
  • Hot  30 replies
  • Hot  36 replies
  • Hot  47 replies
