'03 YZ250F cams in a '00 WR400
6 replies to this topic
  • g-powerr
Posted April 01, 2010 - 12:55 AM
I know that my question might be for the WR section but I'm sure I have a better chance for a good answer here so:
Will both intake and exhaust cams from a '03 YZ250F fit in my '00 WR400? I can get both cams for less than $100 so I think it will be a good deal. Also will I gain some more power with these cams, besides the auto decompression?
Posted April 01, 2010 - 07:07 AM
No, the 250F cams won't fit at all.
The YZ450 cams won't fit as a pair, because you won't be able to time them. Read:
http://www.thumperta...584#post8907584
Refer to the DCM cam thread, link to instructions for details.
Using the '03 exhaust cam provides a nice little boost in power, but the aftermarket stage one cams are easier to install.
  • g-powerr
Posted April 01, 2010 - 08:01 AM
Thank you kindly sir!
It's really hard to get HotCams or any aftermarket cams here, almost nobody ships to Eastern Europe...wish I was born in the USA.
Posted April 01, 2010 - 08:37 AM
Then what you want is a cam from an '03-'05 YZ450. An '06 will also work, but you'll loose a bit of low end (not much)
  • umu24013
Posted April 03, 2010 - 05:48 AM
grayracer513, please help me figure out what combination to use.
I have a '03 yz450f exhaust cam, and a hotcams stage 1 exhaust cam
What would you recommend for best performance in my case (yz426):
a. 03 exhaust cam + stock intake
b. hotcams stage 1 exhaust + stock intake
c. hotcams stage 1 both exhaust and intake (will need to buy the hotcams intake)
Posted April 03, 2010 - 08:24 AM
There isn't really that much difference between the three. If I had the parts you have, I'd probably lean toward :thumbsup: just for the simplicity, assuming the Hot Cams exhaust is an auto decomp cam made for a 426.
  • umu24013
Posted April 03, 2010 - 05:40 PM
Thank you!
  • 10 replies
  • Hot  38 replies
  • 5 replies
1998 yz400f will not idle. by trolley
  • Hot  32 replies
  • On January 15, 2017
