03 450 Jetting help
9 replies to this topic
  • WR450_Rider
Posted March 31, 2010 - 06:00 PM
I have and 03 450 that I bought new. Ive never modded it much until recently when I got back into dirt riding. It has the airbox snorkel removed and holes drilled, a white brothers air filter and e series exhaust with all the discs in, and gray wire cut. Currently it has a 152 main, 48 pilot, 65 starter, 70 paj, 70 leak, and was 3.5 turns on the pilot screw. I have never felt any off idle stumble but just constant throttle stumble. When riding at constant throttle, 1/4 throttle, it stumbles but if I pull the choke it runs better, even when warmed up.
  • TLRam1
Posted March 31, 2010 - 11:56 PM
What sea level are you at? Seems like your needle could stand to be raised or just go to a larger Main jet might be best. I am running a 170 Main in my 04, needle in stock position.
What position is your needle in?
  • WR450_Rider
Posted April 01, 2010 - 05:50 AM
I am at about 600' above sea level. My needle is in the 6th out of 7th position.
  • TLRam1
Posted April 01, 2010 - 10:48 AM
From the top? If so, you for sure have too small a Main Jet. Avg. position of the Needle is in the middle, give or take a notch either way. Stock Main I think is 165 and yours is set up for a high altitude. I am around 500-600 Ft above as you are.
I would at least go back to a stock Main and maybe more, I went from 165 to a 170, and move your needle clip 3 notches down from the top. This should fix you up.
  • CanadianWR450
Posted April 01, 2010 - 11:13 AM
Ditto, I'd try a 168 - 170 main, clip #3, and fuel screw 1.25 - 1.5 turns out as a starter point.
  • WR450_Rider
Posted April 03, 2010 - 06:50 PM
The clip is in the 6th from top now. would the 3rd from top be richer or leaner? I put a 168 main in, 48 pilot, 40 leak, and 100 pilot air jet. I also got an adjustable air screw. The air screw, leak, and paj are on order and due in on thursday
  • CanadianWR450
Posted April 04, 2010 - 02:43 AM
3rd from top would be leaner, but everything interacts together.
Check this out:
http://www.thumperfaq.com/jetting.htm
Your the original owner, and your positive it is the stock needle....right?
I can't imagine why a dealer would jet a bike like that...but...well...you know how some dealers are... :/
Look for "color" on the top of the needle...red, or blue....like this....
http://www.pbase.com.../image/38163739
just to see if it may be a JD needle somehow.....
  • TLRam1
Posted April 04, 2010 - 02:30 PM
I didn't need to mess with this, what is the stock pilot air jet size? i plugged my leak jet, #35 still did not work well for me.
  • WR450_Rider
Posted April 04, 2010 - 03:46 PM
I am the original owner so it is the original needle.
  • bg10459
Posted April 05, 2010 - 07:00 AM
Try this:
165-168 main; 152 is really lean.
3rd clip needle; 6th clip may have been to compensate for the very lean main.
45 pilot, 2 turns; I only find the need for a 48 when it gets cold (< 50).
40 leak.
No real need to mess with the starter or pilot air.
