Yamaha
YZ250 Rebuilt top end, still no compression
7 replies to this topic
  • derek182
Posted March 30, 2010 - 08:56 PM
I have an 88 YZ250. Just rebuilt the top end and theres no compression. It sounds like the air is escaping somewhere inside the top end. Any help?
  • bink98xcab
Posted March 30, 2010 - 09:59 PM
did you put the head gasket or orings back in?
  • derek182
Posted April 01, 2010 - 04:25 PM
yea i put all new gaskets on the top end. i took the air filter off and it feels like air is being pushed out instead of being sucked in. Is that normal? I don't think it is but i really dont know
  • riverat1540
Posted April 05, 2010 - 04:24 PM
could that happen if he has the piston bacwards?
  • T-Rex
Posted April 06, 2010 - 08:15 AM
If you installed the piston backwards you bent all three intake valves = no compression.
  • yubamike
Posted April 08, 2010 - 03:37 PM
88 YZ 250 is a two stroke. Sound like you have a bad or broken reed valve.
  • riverat1540
Posted April 08, 2010 - 05:26 PM
how do the reeds effect the compression? makes no sense to me. once the piston makes the stroke and blocks the ports up the compression has no where to go besides the head, between the rings and the cylinder or out a port if the piston is backwards
  • T-Rex
Posted April 11, 2010 - 10:37 AM
Sorry thought it was a 4-stroke, anyway yes reeds can cause problems. Think of your reeds as a intake valve, if it does not close it will not run correctly. With the reed cage in your hand and looking through it from the intake side you should not see any light, if so there is the problem.
1972 Yamaha 125 enduro help/basic info on the bike needed please! by labelink13
Dirt Bike   Special Interest Forums   Vintage
  • Hot  50 replies
I bought my first bike. by jason125
  • Hot  43 replies
Off-Road
Yamaha vs KTM/Husky by Mongo134
  • Hot  262 replies
Yamaha
07 YFZ478 jetting question. by MrCoty
ATV/UTV   Make/Model Specific   Sport ATV
  • 0 replies
Yamaha
yfz450 random stalling. starts right back up though by ridinredneck
