Rear shock oil?
2 replies to this topic
  • CanadianWR450
Posted March 30, 2010 - 04:45 PM
OK, I have looked everywhere including my manual, and I can't seem to find this anywhere...
What weight do you use for the rear shock oil in a 05 wr 450?
Is it 5wt like the front?
  • GuyGraham
Posted March 31, 2010 - 03:46 AM
Shock oil doesn't come in different wieghts like fork oil
You need a high VI oil for the shock (this is why they are more expensive) so that it doesn't change viscosity much between hot & cold (else you get damping fade)
I use Motul Shock Oil, which has a VI of 400
I know Elka use an Exon industrial hydraulic oil
Fork oils will not have a high enough VI rating and hence you will suffer from fade when hot
Hope this helps
  • CanadianWR450
Posted March 31, 2010 - 02:18 PM
Points me in the right direction!
