Chain slap /sub frame
17 replies to this topic
  • h20mn
Posted March 30, 2010 - 01:21 PM
Have 06 wr450f and the chain keeps hitting the alum. sub frame. I thought I saw a thread about a guy that made a guard that bolted to the swing arm to prevent this from happening. tried doing a search but didnt find anything. Do any of you guys remember the product name or any other solution.
Thanks
  • ASternad
Posted March 30, 2010 - 03:55 PM
One TT'er zip tyed a piece of a chain slider to the frame.
Have you verified chain tension via the manual's suggestions?
  • Strattos
Posted March 30, 2010 - 04:13 PM
As above, it might pay to double check your chain tension. Could be wrong, but I thought this was only a major problem on the '07 onwards bikes.
I had an '02 and didn't have an issue, but have got the issue on my '08.
  • h20mn
Posted March 30, 2010 - 04:49 PM
I check the chain tension before every ride, because I know if it is out of spec. it makes the problem worse. I bought the bike new and have zip tied a heavy piece of rubber belt material to the sub frame. I used up my last piece and cant find any more rubber. looking for fix once and for all.
  • JM450
Posted March 30, 2010 - 06:12 PM
I'm not having any issues with the chain hitting the sub frame but it is slapping the swingarm. I run my chain just a hair tighter than the manual says and it seems to help. I have an 08.
  • KennyMc
Posted March 31, 2010 - 09:56 AM
I believe the noise you hear is coming from the chain slide. Some have chosen to epoxy it to the swingarm or put a thin strip of weather seal under it. :thumbsup:
  • h20mn
Posted March 31, 2010 - 12:20 PM
I don't care about the noise. It the nicks and scrapes the chain is taking out of my sub. frame.
  • OUTERLIMITS
Posted March 31, 2010 - 03:23 PM
On my '08, I try and keep the chain with in the spec outlined in the manual. As far as the slapping nose, it does seem to be pronounced if the chain is on the looser end of the range and more noticeable when going slow. Nothing has touched the subframe on mine yet, but I can see a couple of nicks here and there on the frame where the chain passes by. I have read here somewhere that swapping over to the TM Design chain guide and slider eliminate the slapping noise, is this true?
  • h20mn
Posted March 31, 2010 - 04:47 PM
not sure, I haven't heard of that chain guide. With my bike being the last year of the steel frame, I am not that up on the later years and alum. framed bikes.
  • RSAthump
Posted April 01, 2010 - 01:35 AM
keep it a bit tighter than in the manual sort out the problem:)
  • crazylikeafox
Posted April 01, 2010 - 05:06 AM
had some chain slap on my '03. i changed out my swingarm slider ........problem solved, but i did use a ufo unit because it seemed to be a little thicker.
  • tribalbc
Posted April 01, 2010 - 08:43 AM
I don't know how much the TM guide helps, already had it on. But when I replaced the slider with the TM one chain slap was eliminated :thumbsup:
  • drick
Posted April 01, 2010 - 05:51 PM
+1 for TM designs, it fixed the slap on my '09. i run both the front and rear guides
  • BajaFool
Posted April 01, 2010 - 07:45 PM
H20MN,
Ensure that you are adjusting the chain in accordance with the Owner's Manual. I owned a 2006 WR450F and until I followed the instructions for adjusting the chain to the letter, I had problems with the chain hitting the sub-frame. You are probably performing this task corrrectly, but verify that this is what you do to adjust your chain slack. Follow me on this.
Elevate the bike on a stand; rotate the wheel several revolutions to find the place where the slack seems the tightest; measure the slack from the TOP of the bolt that secures the chain chaffing strip to the Swing Arm to the BOTTOM of the chain between two roller pins (dimension "a" in the Owner's Manual) and adjust to the tight end (closer to 48mm) of the 48-58mm (1.9 - 2.3 in) slack tolerance.
When you adjust your chain alignment, ensure that you check the alignment of the axle using the alignment marks on both sides of the rear wheel and that you are counting from the rear of the adjustment blocks. The alignment block on the sprocket side has 9 alignment marks and the alignment block on the brake side has 11 alignment marks. If you count, starting from the back of the alignment blocks, the marks are equally spaced on the blocks, if you start from the front, the marks are not an equal distance from the center of the countershaft upon which the front sprocket is attached. Counting from the front of the alignment blocks will result in a chain that is not adjusted in a straight line. I hope this helps.
  • OUTERLIMITS
Posted April 01, 2010 - 07:59 PM
H20MN,
This is a really good point and I don't recall my manual saying one word about it. :thumbsup: Could be one of the reasons so many people have chewed up subframes, but likely that Yamaha has a little design issue as well.
  • micahmorgan
Posted April 01, 2010 - 10:29 PM
The thread you are searching for is in the YZ450 forum. There is a problem with the chain slapping on the slider that is then bouncing on the frame. I'll look for it but I might run out of time.
  • klossWR450
Posted April 01, 2010 - 10:37 PM
I guess that's what you need: http://www.thumperta...ght=chain block
  • h20mn
Posted April 02, 2010 - 06:30 PM
BAJA FOOL :
Thanks for the info. I did not realize the different number of marks on the blocks. Went out and check it per your instruction and sure enough I counted from the wrong way I was one mark off. THANKS FOR THE INFO.
h20mn
