How compatible is my yz400f to a yz426 or 450
6 replies to this topic
  • copenhagen101
Posted March 29, 2010 - 10:53 PM
I need a new piston and cylinder and i was wondering if a 1998 yz426f and a 1998 yz450 will work on my 1998 yz400f. If you could give me yous advice that would be great, thank you......
  • sacfelix
Posted March 29, 2010 - 10:56 PM
Yamaha made the YZ400f from 98-99, the YZ426f from 2000-2002 and the YZ450 from 03 to current.
Posted March 30, 2010 - 08:36 AM
If you rebuild your YZ400 crank using a 426 rod, you can then use a 426 piston and cylinder. No 450 top end parts will fit on either a 400 or 426.
  • rmx250rider
Posted March 30, 2010 - 10:50 AM
Would it be as reliable using the rod and cylinder.... can you use the cams out of the 400 in the 426 head?
Posted March 30, 2010 - 11:02 AM
Yes and yes.
  • rmx250rider
Posted March 30, 2010 - 11:15 AM
can I still use the the part off the 400 that goes under the cylinder? I forgot its name
Posted March 30, 2010 - 11:31 AM
The base gasket?
