won't run unless fully choked
6 replies to this topic
  • hunterdane
Posted March 28, 2010 - 04:26 PM
i let the bike warm up for 30+ minutes and it would just die when i would shut off the choke. i think there is a clog in the fuel system somewhere but i don't know where to start.
  • jfgjr
Posted March 28, 2010 - 07:18 PM
Pilot jet. Take old one out insert a new 42 and you should be good to go. You can try to clean the existing one but not worth it IMO. Sometimes sand clogs it and you can't see it because some of the grains are clear. Just loosen the clamps that mount the carb rotate it and pull the 17mm plug at the bottom. It is in a recess that can be reached with a small flathead screwdriver, it's pretty easy. Good luck:thumbsup:
  • rgood4
Posted March 31, 2010 - 07:35 PM
+1 on the 42 pilot. Cured the problem on my bike. Make sure you get the fuel screw properly adjusted as well.
  • Hit_the_set
Posted April 01, 2010 - 05:24 AM
defiantly try the pilot jet.
But you should never let the bike just idle for 30 min. That's torture on the bike. It'll get way to hot. I'm surprised that if you let it run that long it didn't over heat.
  • condor74
Posted April 01, 2010 - 06:36 PM
+1 on the warm up time. The bike will usually come up to operating temp with in about 1 or 2 minutes. After 30 minutes of idling the bike may shut off cause it is overheating. Definitely check and replace the pilot jet.
  • xplant
Posted April 04, 2010 - 03:49 AM
I installed a very small inline auto fuel fitler in the carb supply line over a year ago. We ride sand environments all of the time, but no more dissassembling the bike to clean a jet.
  • hunterdane
Posted April 13, 2010 - 09:16 PM
when you say 42 pilot is that the "slow air" jet because online when i look under 42 for the reference number it says it's the slow air jet
Honda CRF250X 2016 by Chris.GVS
Honda CRF250X 2016
  • Last review by toppo72
  • On November 28, 2016
CRF250X or YZ250X? by Jayzonk
  • Hot  135 replies
Honda Crf250x mods by Son_of_harry14
Dirt Bike   Make / Model Specific   Honda   CRF250X
  • 6 replies
Baja Designs CRF250X General Discussion by Baja Designs
  • 2 replies
Too Much Throttle Response After CCC Mods by Rodeojones
  • Hot  66 replies
