What fuel tuner setting would give a little more low end?
9 replies to this topic
  • Thumper38
Posted March 26, 2010 - 07:17 AM
Just wondering what setting would give alittle more low end ? the FMF exhaust made it very very smooth, I like it but I am just trying different things.
Posted March 26, 2010 - 07:19 AM
Have you browsed the maps that have been posted?
  • Thumper38
Posted March 26, 2010 - 08:13 AM
Yea I have not seen anything that boosts the low end. It seems everything mellows it. Which in turn may be better I was just wanting to play a little!
  • CaptainKnobby
Posted March 26, 2010 - 01:42 PM
Dam!.....With my FMF on the stock map wares me out when on the track cause of so much low end. I like the less hit map when racing and riding cause to me the bike is so much more easy to control and does'nt ware me out as bad.
I guess if you want more bottom just go up in values on the FI side at 1/8 throttle opening. I dont know that for sure but just a thought.
  • jeff14
Posted March 26, 2010 - 03:21 PM
I have the fmf & I agree the low is soft . I feel its rich also so just on the IG side try adding some timing.
+1 0 0
+2 0 0
+3 0 0
I'm running
+2 0 +1
+2 0+1
+3 0+1 Jeff
Posted March 26, 2010 - 04:27 PM
+2 0 0
+3 0 0
I'm running
+2 0 +1
+2 0+1
+3 0+1 Jeff
This is confusing. Is this both maps, or is this a before/after of the ignition map? You said that you added only to the ign side, and that you felt the engine was rich, but when you present the tables this way it looks as if you added to the fuel curve at 4000 rpm. Please clarify....
  • jeff14
Posted March 27, 2010 - 11:10 AM
sorry, it is confusing, they are both IG settings. The top was for him to try, The lower is what I run . the lower adds low & top. Jeff
Posted March 27, 2010 - 12:24 PM
Thanks.
  • Scrubba
Posted March 27, 2010 - 01:20 PM
most want less low end , but there must be a reason why the maufacturers give the stock map the low end hit.
I too have noticed that aftermarket pipes on the EFI bikes take away the low end.
Just curious, but what are the top pros running, as to low end hit?
Does anyone know of reviews of works bikes used by the pros, and how much low end hit do they have on there?
  • jeff14
Posted March 27, 2010 - 01:53 PM
I'm using the pipe for top end & the tuner for the low & to mod the power band for the track. As far as the pros [ works] bikes I sure each rider tailors his power the way he wants it . Those guys have no trouble getting the power they need . Heads, cams,custom pipes, fuel, ect . Massive power everywhere I assume .Jeff
  • 5 replies
  • Hot  113 replies
  • 0 replies
  • Hot  36 replies
