01' 462f Carb cleaning
2 replies to this topic
  • mgb_tracker
Posted March 25, 2010 - 06:51 PM
I've posted once before, but only now have i had an opportunity to actually start on getting my ole YZ going. My ride is an 01' 426 that i had rode 1 season and ended having to give up riding due to unforseen circumstances. Flash forward 8 years and trying to get this beast running again.
During my inspection, i noted that i had emptied the tank when i had quit riding it, so it was pretty clean inside. I pulled the plug at the bottom of the float bowl and it was pretty nasty stuff in there. A light carmel color and pretty thick stuff. I spayed a little carb cleaner in the gas line inlet and let it sit for a bit. I thought i should at least attempt to get it started before pulling the carb and such. I put some fresh gas in and replaced the spark plug and at first it wanted to start, but i think it was just the carb cleaner burning off. At this point, i'm pretty sure i need to pull the carb and do some cleaning.
My questions to you folk is, what kind of cleaning should i start with? I'm not very familiar with this type of carb. Should i do some form of soak or just a good spray down? Is there anything i should be careful with etc...?
TIA for your thoughts and suggestions,
-MGB
Posted March 25, 2010 - 07:31 PM
Don't soak it, don't remove the TPS from the carb, and don't separate the upper and lower halves of the carb body (the joint above the float bowl) .
Read:
http://www.thumperta...726#post8021726
  • mgb_tracker
Posted March 27, 2010 - 07:00 PM
Pulled the carb, sprayed it out and made sure all the old gas was out.
The beast is now running!
Thanks,
-MGB
  • Hot  30 replies
  • 5 replies
  • Hot  36 replies
  • Hot  113 replies
