2007 YZ450 - Steering Bearigns
10 replies to this topic
  • ticke2110
Posted March 22, 2010 - 09:48 AM
Needing to replace the Bearings as bike's handle bars stick after a while of in-activity. Looking on-line, under OEM Steering it only shows 1 set of bearings needed but it's my understanding that if this is to be done right, 2 sets are needed (Top & Bottom). Would I be correct i my understanding that the diagram under the "Steering" section is for the Top Bearing and if so, where can I find the Bottom Bearing ? In anticipation ... Thanks for your help. :thumbsup:
Posted March 22, 2010 - 09:55 AM
The bottom bearing is listed under "Front Fork".
Be sure to use the revised top bearing, 93332-000[COLOR="Blue"]78[/COLOR]-00, not the older, 93332-00068-00.
  • ticke2110
Posted March 22, 2010 - 09:58 AM
Thanks You...So the one shown on the Steering is for the Bottom ?
By the way - Say Thank You to your son for what he's doing - "Proud Father of a U.S. Marine Designated Marksman"
  • ticke2110
Posted March 22, 2010 - 09:59 AM
Sorry - stupid comment about the Top/Bottom bearing - I read and did not digest.
  • letitride
Posted March 22, 2010 - 02:52 PM
If you don't go OEM you can get both bearings, the bearing race's, and seals from All Balls for just a little more then the price of just 1 OEM bearing. Generally I pefer OEM for most parts but since the stearing bearings usually wear out from getting dirty, I'll bet the ALLBalls will last just as long or maybe I should say will probably wear out just as quick. Stearing head bearings need to be cleaned and greased at least every year.
  • ohioryder
Posted March 27, 2010 - 10:10 AM
Do you know what year or when Yamaha went with the newer bearing?
Posted March 27, 2010 - 10:42 AM
It was introduced as a service part in '07, but didn't make it into production bikes until late '08, or so.
  • myoung
Posted March 27, 2010 - 09:10 PM
My '09 was built with the old style #68 bearing. Just replaced top and bottom at 35 hours, they were both done! I hope this new sealed bearing will last as long as the ones on my 426 have.
  • Polar_Bus
Posted March 28, 2010 - 04:57 AM
If you ocassionally use a pressure washer, try to stay away from the steering neck. IMO I think pressure washing accelerates the stem bearings rusting. My buddies '06 bearings actually rusted so bad, they siezed up tight over winter storage !
Edited by Polar_Bus, March 28, 2010 - 12:36 PM.
  • ohioryder
Posted March 28, 2010 - 06:23 AM
My 08 wr450 came with the older bearings. I just had to replace the bottom bearing. The top bearing was perfect, although the dust seal was torn from the factory. My sons 08 yz250f had a torn dust seal too. I think they could come up with a better design for it.
  • myoung
Posted March 29, 2010 - 02:59 PM
While this is completely true, my 426 has survived countless pressure washings, my '09..............not so much.
I always avoid the stem area as much as possible, but on my '09 it still got in there. :thumbsup:
  • On Yesterday, 06:20 PM
  • 10 replies
  • Hot  50 replies
Motocross
  • Hot  491 replies
