Headlight Removal
2 replies to this topic
  • crazylikeafox
Posted March 21, 2010 - 01:26 PM
Does anyone out there have any pics of the headlight removed from a wr? What front no. plate was used? Where was the ignition button installed? Any advice would be great. Thanks
  • spockmoon
Posted March 21, 2010 - 05:27 PM
Firstly take the speedo and all associated brackets off. Also take the top brake line guide off. Tape up all the loose electrical connectors you don't need then use a yz450f front plate hack the top mount off and then cable tie top to forks just place a couple of small holes in the plate to do this.
The start button is a little more complex I just manufacted a little bracket from a peice of aluminium checker plate. Using the original as a guide I used the flat mount part and extended it so that I could use one of the speedo bracket mount holes/bolts under the triple clamp to attach to the bike. ending up like so
  • crazylikeafox
Posted March 21, 2010 - 07:18 PM
thanks..........looks great
