spark plug corrosion
3 replies to this topic
  • crush6742
Posted March 21, 2010 - 05:19 AM
I changed the spark plug on my '08 YZ450f, and I noticed there was some rust corrosion all around the metal base of the plug. I'm assuming the rubber boot for the spark plug cap was not properly pushed down and sealed, and moisture entered in the housing. After I removed the plug I noticed some of the corrosion stayed on the aluminum head where the plug seals to the engine. I tried to clean some off with a rag and a small tube to push the rag down the shaft. This was not very effective, although it did clean some of it up, and there wasn’t a lot to begin with. Is there some something I can use to clean this up, or is this something I should not be concerned with. Bike starts and runs fine. I just don't want the corrosion that's there to continue to corrode my new plugs. Also, I bought come electrical spark-plug sealant at the auto parts store. I used this to put around the boot of the spark plug cap to get a better seal.
  • andy250
Posted March 21, 2010 - 07:34 AM
More than likely you're spraying water into the spark plug drain hole (located on the clutch side) while washing the bike. A golf tee works great to plug this hole...
  • l_campionero
Posted March 21, 2010 - 07:40 AM
Blow air into the hole described above, then spray WD-40 in there.
  • crush6742
Posted March 21, 2010 - 07:59 AM
Thanks for the advise. I wasn't aware of the drain hole. That makes sense. What's the best way to get the corrosion that's there out?
  • Hot  36 replies
  • Hot  30 replies
  • 5 replies
  • 0 replies
