shift lever
4 replies to this topic
  • Boit
Posted December 26, 2000 - 09:40 PM
Is it me or does anyone else have a problem with their boot slipping off the shift lever when trying to upshift in damp or muddy conditions? Is there a better aftermarket lever that gives a good grip with the boot?
  • motoman393
Posted December 26, 2000 - 09:58 PM
I used a moose gear shifter on my old XR400 and loved it! It was a lot better than stock ...stronger and gripped better!
Garrett
I get my kicks on a 2001' YZ426!
Friendswood, TX
  • jimt_yz400
Posted December 27, 2000 - 02:38 PM
I'm having the same pblm with my new 250F.
My foor keeps slipping off of the lever causing it to not shift or find false neutrals (BAD!!). I was thinking of going to a longer shift lever or use the one off of the old 400.
  • Hick
Posted December 27, 2000 - 03:03 PM
I was trying out a buddy’s pair of Gaerne boots and had the same problem. I guess the toe on my Tech 6 (and old Formas) is grabby enough to overcome what is now a pretty slick lever.
How ‘bout wrapping the end with grip tape (like skateboarders use)?
  • Boit
Posted December 27, 2000 - 06:55 PM
The earlier 400 had a different lever design? I wasn't aware of that. Maybe that would be a consideration. If the Moose works good, I'd probably go with that since moset aftermarket parts are much less expensive than stock...and in many cases, superior.
Hick: I'm using Tech 7's. They work great as long as it's dry. That skateboard tape sounds like a good idea...there's a skateboard/BMX shop near me and my twin sons are sponsored riders...maybe I can get a killer deal on that tape... :)
