Header dent: need advice
14 replies to this topic
  • ArcticWR400
Posted March 18, 2010 - 09:43 AM
Hi all;
Running a 1999 wr400 with all the popular mods done by the PO.
The problem: Header has a couple dents in it, looks like it's been dropped on a rock. Dent 1 is roughly the size of a dime, about 1/4 inch deep, and Dent 2 is roughly the size of a quarter, 3/8 inch deep. Is this going to wreak some havoc on my power? Create hotspots on the pipe? Possibly dmg anything? Is it worth paying the 250 bucks for a new aftermarket powerbomb header?
Also, was thinking about repacking the muffler to make the noise levels a little more rider-friendly, as 2 hours on the bike gets hard on the hearing... I'm not entirely sure there is any packing in the current muffler. Will I need to re-jet?
Any insight would be appreciated... first time 4 stroke owner, first time 4 stroke maintainer.
Edited by ArcticWR400, March 18, 2010 - 09:44 AM.
Spelling is hard >.<
  • byggd
Posted March 18, 2010 - 10:14 AM
Fill the area of the dent with water ... cork both ends and put it in the freezer. As the water expands it will push the dent out. You may have to repeat a couple of times but it works!
  • BAHeron
Posted March 18, 2010 - 10:33 AM
Check E-Bay for a used stock one. I bought one a while back there.
  • ArcticWR400
Posted March 18, 2010 - 11:58 AM
Seriously? Never thought of that... it's GENIUS :banana: Thanks!!!
  • h20mn
Posted March 18, 2010 - 03:41 PM
I can second that, in the 1970 I used to put my two stroke pipe in the freezer in the garage. Mom didnt care for it but it does work
  • byggd
Posted March 19, 2010 - 01:17 PM
Seriously? Never thought of that... it's GENIUS :thumbsup: Thanks!!!
It sure does. Do a search. Many others have used this method.
  • 123BigcoopDawg576
Posted March 19, 2010 - 01:47 PM
Posted March 19, 2010 - 07:36 PM
I took a golf ball sized dent out of a WR450 pipe with the freezer method. By the time I finished working the dent out of the heat shield with some body hammers and some sanding you'd hardly tell it got mashed. I believe the thicker stainless pipe from the YFZ450 quad would work on your bike. I know it works for the earlier 450's
  • ArcticWR400
Posted March 27, 2010 - 01:55 PM
Ok, so my header is in the freezer as we speak, I should have taken some "before" pics to show you all, but seeing as I failed that, I will just let you know how it turns out.
Thanks for the advice and pointers!:thumbsup:
  • Birdy426
Posted March 27, 2010 - 08:19 PM
You shouldn't have to re-jet when you re-pack the muffler. It will run better, tho...
  • ArcticWR400
Posted March 28, 2010 - 08:02 AM
It worked like a charm! The two main dents are completly gone. The only evidence is some dirt / corrosion that was sitting in the dent!! I will be getting full flow through the pipe now, looking forward to seeing if it changed the way it rides at all, even if minorly.
Packing, new handlebars (renthals) and a chain slide (swingarm protector) are on their way from the TT store... and my local dealership has my new grips in already. Can't wait to get this baby geared up for summer! New chain and sprockets next month, and perhaps a new headlight and I'll be getting hot under the collar waiting for spring... or I'll just tough it out and use the studded tires and ignore the cold! WOOT!!!
  • byggd
Posted March 28, 2010 - 03:27 PM
  • umu24013
Posted March 29, 2010 - 06:20 AM
It didn't work on a PowerBomb header :thumbsup: or very little. 15+ cycles.
  • ArcticWR400
Posted March 29, 2010 - 11:01 PM
from what i've since read, it won't because of that larger section and the stresses of teh metal. Also won't work on 2 stroke expansion chambers, which is kinda what a power bomb header is like, a small f'd up expansion chamber that looks like your exhaust pipe has a tumor. works just on the 4 stroke pipes that are more or less the same size from head to mid pipe i think...
  • umu24013
Posted March 30, 2010 - 06:29 AM
I think it depends on the thickness of the metal. Doesn't it?
