spings
1 reply to this topic
  • JamesNad
Posted March 17, 2010 - 05:14 PM
i got a 04 yzf450 that i need fork springs for sense i cut the ones in it for ice riding.
im 140 pounds and am going to be riding mostly trails and some tracks and i would say im a top c class rider when i tracks.
so what fork springs should i get and where should i get them from?
  • DPW
Posted March 18, 2010 - 05:19 AM
Race Tech
Type of Riding: Motocross
Rider Weight: 140 lbs
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.434 kg/mm (use closest available)
Stock Fork Spring Rate: .460 kg/mm (stock)
REAR SHOCK SPRING
Recommended Rear Shock Spring Rate: 5.14 kg/mm (use closest available)
Stock Shock Spring Rate: 5.3 kg/mm (stock)
MX-Tech
Stock Spring Rates:
Fork: 0.45 kgmm
Shock: 5.3 kgmm
Recommended Spring Rates:
Fork: 0.41 kg/mm
Shock: 5.0 kg/mm
http://racetech.com/
http://mx-tech.com/
both sites have spring rate calculators that give you an idea of what you need..
  • Hot  30 replies
  • Hot  113 replies
  • 3 replies
  • Hot  36 replies
