how many still on stock clutch?
13 replies to this topic
  • MikeOK
Posted December 24, 2000 - 05:51 AM
I'm still on mine, but I need a winter project. How many of you are still using your stock clutch basket? And for a Hinson, who has the best price? Tanks...
Merry Christmas
Mike
  • smitty33
Posted December 24, 2000 - 07:31 AM
Don't limit your self to just the hinson dude, I have the Performance Engineering basket and it works killer!
Check it here: http://www.peracing....arts/frame.html
Merry MX-mas
Smitty
Hold it Wide...
http://www.fastbydesign.com
  • Scott_F
Posted December 24, 2000 - 07:45 AM
I just took apart my '00 clutch, and the basket and hub are still in excellent condition after one year of riding.
  • holeshot
Posted December 24, 2000 - 08:06 AM
The clutch basket on my '00 426 was in excellent condition, so I removed it and made it into a clock (because it has twelve tangs). I was going to post a picture of the clock a few weeks ago, but the developers messed up the film.
I installed the Hinson basket because it has slots in the tangs to provide more oil to the plates, but it has not completely solved the grabby problem, only improved it. Why some have problems and others don't is still a mystery to me.
  • Guest_Guest_*
Posted December 24, 2000 - 12:40 PM
I ride my 00 426 every weekend and a few cc races and haven't replaced mine yet. I did break my rear hub a couple of weeks ago- loose sprocket bolts.
  • Guest_Guest_*
Posted December 24, 2000 - 02:27 PM
The clutch in my 00 426 seems be working fine although it only has about 15 rides (all MX) on it.
I'm also currently replacing a rear hub that broke due to the sprocket coming loose. Hopefully I won't have any clutch problems because I can't afford to fix after replacing the hub and getting a new chain and sprockets, although it sounds like Yamaha actually stepped-up and replaced most clutch failures free of charge...if they'd only do the same for the rear sprockets coming loose ! Enough bitchin.....
Merry Christmas and Happy New Year !!
CJF
  • FOX426
Posted December 24, 2000 - 04:04 PM
One year on my 00426 stock clutch still fine. I attribute this to Honda HP4 semi-synthetic oil and rarely using the clutch.
The world loves talent but, pays off on character.
  • Boit
Posted December 24, 2000 - 05:33 PM
Installed the Hinson about 2 months ago as insurance. The stock one looked pristine.
  • EMARacing
Posted December 25, 2000 - 09:20 AM
I went for 9 mos and about 12 hare scramble races on my stock clutch. Upgrading to a Hinson now for the new season.
John E. Walker
#910
  • mike_dean
Posted December 25, 2000 - 03:28 PM
70+ hrs of mx, and 50+ hrs of sand on state trails, still my stock clutch, works fine but has grabbed when cold first taking off since day one. my sprocket bolts also came loose but I caught it before it damaged hub. I love the bike. thinking of sending my forks to mx-tech, they seem to sag and are weak in the middle of the travel, they seem to blow right through the mid-range. has anybody used mx-tech? good results?
  • MikeOK
Posted December 25, 2000 - 03:30 PM
mike- I had the same thing with my forks, I raised my oil level with great results so you might try that before you spend too much money on them...
Mike
  • DaveJ
Posted December 25, 2000 - 08:48 PM
I don't use the clutch very much, but at 163 hours on the bike it still feels great. Did a physical check at 121 hours and all looked well.
I was thinking of switching as well, but since I don't race, I think I'll just wait for this one to wear out or fail.
  • MXOldtimer
Posted December 25, 2000 - 08:57 PM
8 months of MX abuse on my stock clutch and other than being a lil grabby from day one, alls still well (knock on wood).
Doug
  • BBRguy
Posted December 26, 2000 - 04:22 AM
i have a complete hinson clutch assembly. its a work of art. a little tricky to install. but its head and shoulders over stock. stock is good. but if you want the best go for a hinson. killer. my stock clutch blew up. causing 2000 of engine work. wont happen again. hinson.
  • Hot  47 replies
  • Hot  28 replies
  • 5 replies
  • Hot  38 replies
